what exactly is voltage ?
more the charge in a point more the voltage?
In the pic I attached there are two posible paths for electrons to flow.
.path 1 through variable resistor 'R'.
.path 2 through voltmeter.
As I increse the resistance flow of electrons decrease in this path and volt meter shows Increased voltage.
so the voltage depends on that number of stationery charges ? if not, then on what ?
for example I took two plated and held them very need(capacitor, but i am not talking about capacitor here i want to understand voltage) and applyed a e.m.f source to both the plates, from one plate many electrons sucked and on the other plate ample electrons available, so in that way one plate is - charged and the other is + charged.
a) Current is a flow of free electrons, electrons have -charge, more the passing electrons more the current is and more the charge is.
b) e.m.f. is a external force which makes the elecrons move,generator and battry.
please correct my understanding if I am wrong on any of the points i mentioned above.
Thank you for your help friends.
