M
Michael Kennedy
I've got a Sony SDM-HS73 LCD monitor and it has an intermittent problem.
Sometimes it will power up and work just fine but other times you can't get
any thing to display unless you unplug the vga cable and then the it will
display no input. If you plug a vga cable into it at this point most of the
time the picture will just go blank.
I've got the service manual for the hs74 which is similar but has DVI and
VGA. I went through the SM with the HS74 and in the no raster
troubleshooting it says check pin 705
Service manual for the SMD-HS74
