What does RT mean on a pcb
Discussion in 'Electronic Repair' started by rupert, Mar 10, 2007.
  1. rupert
    rupert Guest
    hi i am a self taught repairer of basic electronic items and have been
    doing it for about 4 years, as i buy faulty items repair them then
    sell them on but i have a batch of about 25 PVRs i have repaired about
    20 of them but there is one part on the last 4 that i need and cant
    identify
    It is on the power supply board
    it is labelled RT1 and looks alot like a small capacitor
    it has the marking 8S100L on it
    it is one of the early components on the board (next after the fuse-
    F1))
    please help as i have repured the rest of the board but am sure that i
    need to replace this aswell as it is showing scorch marks
  2. James Sweet
    James Sweet Guest
    Probably a MOV for surge protection.
  3. Eeyore
    Eeyore Guest
    It's a 'surgeguard' style NTC thermistor. Have you measured them ? They can run
    quite hot btw.
    Graham
  4. Eeyore
    Eeyore Guest
    They look similar to NTCs too. The MOV will be 'across the line' where an NTC
    will be in series.
    Graham
  5. rupert
    rupert Guest
    hi THANKS ALOT its an NTC then but how do i find the value of the one
    i need
  6. Ross Herbert
    Ross Herbert Guest
    Highly likely that RT means Resistor - Temperature (dependant).
    It will be a NTC inrush current suppressor.. Since the unit is not
    likely to be using more than a couple of 10's of watts at most you
    could use one such as this
    http://www.ametherm.com/Data Sheets/SL08 10001.pdf
  7. Eeyore
    Eeyore Guest
    Measure a good one ?
    They're specced by surge capability (related to size) and hot and cold resistance.
    You should be able to find a suitable replacement from that.
    Graham
  8. rupert
    rupert Guest
    THANKS FOR YOUR REPLIES I GET SOME ON ORDER!!!
  9. Guest
    Could this device (or similar) be put in series with my halogen puck
    lights that keep blowing bulbs - and would it help?
  10. Eeyore
    Eeyore Guest
    Yes it could.
    It might do. It will certainly reduce the inrush.
    Graham
  11. Ross Herbert
    Ross Herbert Guest
    Could you please explain what a "puck light" is?
    I am familiar with the standard halogen downlights operating from ac
    mains supply via a transformer but not knowing the specifics of your
    particular halogen I couldn't say whether the NTC would help.
  12. it is labelled RT1 and looks alot like a small capacitor
    Is it a microprocessor PCB? Does it say "RTS"?
    "Return to sender, address unknown".
    But that's just a guess...
  13. James Sweet
    James Sweet Guest
    I would guess he means the hockey puck shaped halogen fixtures meant for
    mounting under kitchen cabinets.
  14. Jim Land
    Jim Land Guest
    wrote in
    When that happens, start by taking an accurate voltmeter and measuring the
    AC voltage on the lamps. If it's too high, of course they will keep
    blowing.
    What about other light bulbs? Do they keep blowing too? What is the
    voltage at an outlet?
