what do you mean by feedback circuit biasing?
Discussion in 'General Electronics Discussion' started by diaryrashid, Dec 3, 2012.
  1. diaryrashid
    diaryrashid
    10
    Nov 25, 2012
    hello...can someone tell me what do you mean by feedback circuit biasing?
    thanx
  2. Rusty
    Rusty
    16
    Nov 30, 2012
    Im not sure what you are asking for. Can you specify a little bit more? Op amps, transistors, what are you interested in knowing?
    Feedback, especially negative feedback is very common in electronics. Think Op-Amp and other differensial amplifiers. In a circuit with lots of gain and good bandwidth.. Then negative feedback is used to scale down the gain. It increase the stability and makes it possible to get high bandwidth and less noise - linearity. It's also easier to compensate an input and output of an amp with negative feedback (depends if you want current or voltage in/out)
    Positive feedback is being used for different reasons. Mainly in oscillators and comparators/schmitt triggers.
    Transistors can be feedback biased too. Read more about them here:
    http://www.allaboutcircuits.com/vol_3/chpt_4/10.html
