Well hello! I'm a new guy looking for some help, since I've never done PCB work before.
I'm not sure what type of fault I'm looking for, so I'll just describe the problem, I guess. I was using a mid-80s MCS amplifier in a DIY stereo with the amp and speakers all in one big box. Sort of a boombox on roids.
The amp has three separate but connected boards: power board, equalizer board and a control board with all the buttons and switches on it. I was testing the rig and it was sounding awesome when I accidentally dropped the EQ board on the power board's heatsink, which is aluminum. The fall was only an inch or two, not great enough to damage the board.
There was a ton of snapping and popping once it hit--probably because nothing was grounded--and when powered back on, the audio could be heard through any input no matter which was used, (though it now sounds like a very, very distant radio station with a ton of static) and literally nothing works. I can't change the input, or turn up the volume, nothing--even the LEDs on the boards won't power on.
I checked, and there's no obvious damage, like fire or melting silicon, so I don't even know where to look. I do have a multimeter and a soldering iron, but I've never done repair before and don't know where to start. Any help would be very greatly appreciated!
