what connector size
Discussion in 'General Electronics' started by RB, Jan 29, 2006.
  1. RB
    RB Guest
    Got several unmarked coax lines of different OD sizes.
    I need to use some twist on bnc end connectors, as my application requires
    occasional need to remove the connectors to pull the cables though a small
    hole, then later reinstall the bnc ends.
    The bnc twist on connectors come in several sizes.
    Is there a chart or table that will tell me what coax type I likely have by
    the OD measurement?
    Do I need to trim a short length off the coax cable end each time I reuse
    the bnc twist on fittings?
  2. Not that simple.. Twist ones need the correct center conductor wire
    diameter. RG 6 and RG59 cables have different sizes eventhough the jacket OD
    is the same.
