What are these?
Discussion in 'Power Electronics' started by Pharaday, Sep 11, 2019.
  1. Pharaday
    Pharaday
    101
    3
    Jan 18, 2016
    What are these? Google doesn't know from the label. They aren't LEDs (or they're blown). Thought maybe photo sensors? Can't detect voltage in the 0-20V range ..... what the heck??
  2. Pharaday
    Pharaday
    101
    3
    Jan 18, 2016
    err.... then I found another one on the main PCB (car sterio) and the board where its attached is labeled "LED1" sooooo.... what the heck... I tried every voltage known to man (starting at 1v, I didn't blow them)...
  3. Harald Kapp
    9,856
    2,084
    Possibly infrared LEDs? try looking atthem with your smartphone camera. These can often detect ir light (shown as a bright spot).
    Make sure to limit the current to approx. 5 ma ... 10 ma when testing.
  4. Pharaday
    Pharaday
    101
    3
    Jan 18, 2016
    ok I'll try that but one of them was found way inside the stereo where I don't think it could recieve anything or get a signal out. But I'll try your thing...
    Edit:
    No, I couldn't notice anything with my phone camera when I hastily tried powering those LEDs from 3v up to about 12... maybe the problem is ME
  5. Harald Kapp
    9,856
    2,084
    Current limited? Did you measure the current? At these voltages any LED will long be gone.
    What does the other side of the PCB look like?
    From the look of it I doubt these are LEDs. No encapsulation - the chips would long have deteriorated. Could these be contacts for pushbuttons?
    thedoc298 and davenn like this.
  6. Pharaday
    Pharaday
    101
    3
    Jan 18, 2016
    It's hard to tell but those 2 metal prongs inside our mystery part are incased in a small rectangle of clear plastic.
    Looking at the PCB, I noticed that there is holes on the back side, possibly for some form of light to get through? Either visible or not.
    Having blown more than my share of LEDs I know what it looks like, a sudden flash of super bright light followed by the LED not working. I'm pretty sure that's not what happened here.
    I won't be able to sleep until we solve this....
  7. Harald Kapp
    9,856
    2,084
    Not necessarily if these are IR LEDs. measuring the current brings clarity.
    Looking real close:
    1) looks like a bonding wire
    2) looks like an LED chip
    which supports the idea that these are LEDs (this one looks rather similar)
  8. Pharaday
    Pharaday
    101
    3
    Jan 18, 2016
    Well you know what, who knows maybe I blew them. unforch, I bought a multimeter that's just a dual meter; it only measure voltage and resistance, so I guess we could calculate it. I used the same thing I test all LEDs with cause it never burned out any other LEDs. I used a 9v battery plus a 100 ohm resistor. sooo ummmm I=V/R > I=9/100=0.09 amps? Did I... it's been a long time since circuit analysis...
  9. Pharaday
    Pharaday
    101
    3
    Jan 18, 2016
    See, this is why I got a B in circuits.... brown black red, that's a 1kΩ resistor, sir. and I measured the battery voltage to be 7.68V so can I change my quiz real quick? I=7.68/1000=0.00768A, couldn't have blown them. Plus you usually see black burns in a blown LED right at the juncture of those 2 prongs, especially in clear ones.... I have blowing LEDs down to a science.
  10. Audioguru
    Audioguru
    2,786
    632
    Sep 24, 2016
    If you connect the resistor across the battery like you said without an LED in series then the current is what you calculated. Are you trying to light up the resistor?
    An LED has voltage across it that reduces the voltage across the series resistor so that the current is less than you calculated.
    The battery voltage might be 7.68V when not loaded but if it is old then it could be 4V or less when connected to your LED and resistor. So the actual voltage and current in your circuit might be too low to light the LED.
  11. WHONOES
    WHONOES
    854
    206
    May 20, 2017
    Have you tried swapping the battery polarity over?
  12. Harald Kapp
    9,856
    2,084
    I'd expect the cathode to sit in the cavity (no. 2 in post #7), anode on the flat part (no. 1).
    But things may be different...
  13. Pharaday
    Pharaday
    101
    3
    Jan 18, 2016
    Sorry, I didn't notice there were more replies. Yes, I tried flopping polarity. And yes I forgot to take into account the LED in my V=IR. I'm pretty sure I didn't blow the LEDs. Maybe they were all blown along with the stereo? Bottom line is that these PROBABLY LEDs sit in with the rest of my FOR SURE LEDs, forever a mystery. How can we sleep with this hanging over our heads? Only time will tell.
