What are these capacitors?
Discussion in 'Datasheets, Manuals and Component Identification' started by aleeeeaaa, Dec 15, 2017.
  1. aleeeeaaa
    aleeeeaaa
    17
    Jan 31, 2011
    I have two capacitors on a toshiba motherboard i need to identify the values. They are electolytic surface mount and both are black and silver on the top. One has 05, 100,16A on it and the other one has 01, 100 ELA.
  2. davenn
    davenn Moderator
    13,709
    1,909
    please show a photo of each of them
    tho I suspect both are 100uF
    this one --- 05, 100,16A 16 most likely indicates 16V rating
  3. aleeeeaaa
    aleeeeaaa
    17
    Jan 31, 2011
    Here is the picture of the caps.
  4. davenn
    davenn Moderator
    13,709
    1,909
    the silver/black ones are the same ... no difference in numbers or letters as you stated in your first post
    they have ....
    0t
    100
    ELA
    =100uF as I stated earlier ... not sure of the voltage ? you could measure the voltage across either of them when the unit is powered up
    Probably either 6.3V or 12V
    the top one of the 3 visible (with red on it) ...
    OM1
    330
    6.3v
    = 330uF 6.3V
  5. aleeeeaaa
    aleeeeaaa
    17
    Jan 31, 2011
    Thanks for looking. I/m going to order some replacement caps in those values.
  6. Robert_fay
    Robert_fay
    124
    34
    Jun 15, 2017
    It could be that the "E" in the black/silver is also a voltage call out.
    dorke likes this.
  7. aleeeeaaa
    aleeeeaaa
    17
    Jan 31, 2011
    Thanks, i hadn't come across this chart. I think the problem is solved.
