What are real example of " While Loop"
Discussion in 'Microcontrollers, Programming and IoT' started by vead, Jan 14, 2018.
  1. vead
    vead
    473
    14
    Nov 27, 2011
    I do not know whether this question should be asked or not but I am confuse. This is reason reason I am asking here.
    I wanted to know how do we use while Loop in c language I wrote program and read about while loop in my book.
    I thought I should write my own programs
    so, I made some examples for while loop
    • Keep light On until user closes it
    • Enter password until the user enters correct password
    • Do not stop the machine until its temperature is 30* c
    • Fill the water in the bottle until it is empty
    • Play the songs until the user stop it
    Code:
    while ( user doesn't close it)
        Keep light On ;
    while ( user doesn't enters correct password)
        promote user to enter correct password repeatedly
    while (temperature is 30* c)
        run the machine continuously
    while (bottle is empty)
        fill water in bottle contentiously
    while ( user doesn't stop)
        play all songs repeatedly
    I think all these examples are correct but I am not sure weather its false or true. I just want to know, Am I getting right point about while loop. Is all these examples correct? Do I need to improve example for "while loop"?
  2. Harald Kapp
    9,540
    1,967
    These examples look fine.
    vead likes this.
  3. Gumby_Kevbo
    Gumby_Kevbo
    11
    6
    Jan 25, 2018
    Many embedded control programs are contained in a " while(1)" loop....the main loop that keeps repeating as long as the power is on.
  4. Nanren888
    Nanren888
    163
    30
    Nov 8, 2015
    How's arduino go? Setup & loop?
    setup();
    while(1)
    loop();
    end
  5. ramussons
    ramussons
    344
    63
    Jun 10, 2014
    Its good practice to include a "break" statement to exit from the "while loop" routine without having to power off.
    while(......)
    { do the following
    {if (.............)
    break
  6. Kabelsalat
    Kabelsalat
    117
    22
    Jul 5, 2011
    Ther is the while loop, and also much used do/until (terms may differ in other programming languages).
    The while loop executes zero or more times until a condition is true. A do/until (or do/while) loop runs one or several times until a condition is true.
    It may be easier to explain using labels / goto, like this:
    while (condition) {
    do_something()
    ; is the same as using labels like this
    label:
    If (condition) {
    do_something()
    GoTo label
    Do
    do_something()
    } until (condition)
    label:
    do_something()
    If !(condition) {
    GoTo label
    So if I decide to pick up a phone call from Indian Microsoft (scam) and decide to waste their time, it'll probably look something like this:
    while !(phone_is_ringing) {
    just_do_whatever()
    If ( caller() = scammer() )
    say("hello")
    Do
    Do
    listen_to_scammer()
    convince_yourself_that_its_all_lie_and_dont_care_to_listen()
    } while( scammer_still_talks() )
    If !( scammer_hang_up )
    spend_time_giving_away_awasteof_nonuseful_information()
    } Until ( scammer_hang_up )
    Edit: won't get indents to appear right, after posting.
