[/URL][/IMG]
[/URL][/IMG] I'll preface this by saying that I'm not an electronics guys and know just enough to make things worse but.... I'm trying to test these MOSFETs and this relay on a cicuit board out of a cheap mig welder to see if they're bad. I've watched a few videos to see how to test the MOSFET but I'm not sure how to interoperate the readings I'm getting. I'm not even sure exactly what setting I have my multimeter on but I'll post a pic of the function I'm testing on. Also, the components are still attached to the board. I'm not sure if that matters? I'm testing both mosfet the same way with negative lead on the source pin and positive to the gate and drain pins seperatly.
One of the mosfet is a IRF640N. On this I get a multimeter reading of .338v between source and drain and a reading of .728v between source and gate.
On the other mosfet IRF510 I get .506v between source and drain and 0 between source and gate.
Also, how can I test that relay?
[/URL][/IMG] The problem I'm trying to fix is a mig welder with a feed motor that no longer feeds. The motor is good, I've taken it out of the machine and powered it up and it runs fine. All the other functions of the machine operate fine. I'm just not getting power to that motor and it's somewhere at the board. I've tested all the connections afyer the board and they're all fine. A general look at the board, everything looks fine. Nothing appears to be melted or burnt except a couple pins on the IRF640N mosfet that look like they could have been pretty warm at some point?
What do you guys think?
