what a daisy chain is ?
Discussion in 'Electronic Design' started by [email protected], Jul 3, 2007.
  1. Guest
    Hi everyone,
    It seems a simple question.But I still have something i
    cannot completly understand.
    A daisy chain is often used a mulidrop topology, which need an
    end-termination. And, source-termination doesnot work properly in
    daisy chain,because the device in the middle of the chain would get a
    plateau.
    So, in a design , i should figure out minimul distance between,
    say two receivers. in other words, beyond what distance between two
    receivers , source-termination should not be used, and this topology
    can be named a daisy chain?
    Driver-------------------revceiver_1----------------------------------
    receiver_2
    distance----------------------|
    thank you all!
  2. neon
    neon
    1,325
    Oct 21, 2006
    daisy chains refers to a ground sckeme wherby amp A ad B and so forth are strung sequentualy in serial matter as opposed to amp having its own gnd from the source. implication I*R drop on any one wil introduce signal to the rest.
