Well there's your problem! Can you help me identify this part?
Discussion in 'General Electronics Discussion' started by Braeden Hamson, Apr 12, 2018.
  1. Braeden Hamson
    Braeden Hamson
    199
    13
    Feb 18, 2016
    TL;DR I need to replace what I think is a diode labeled AXJ82
    So my brother pulls his Blofeld synthesizer out of his clothset, saying it turns on but does not output audio. I say okay and begin to take a look at it. He points me to a 5K Ω resistor which commonly goes bad. I notice there is continuity on the resistor, which is odd. I also check the trace that is nodal with one side of the resistor and another point nodal to the other end of the resistor again continuity and 0 Ω. So I figure I'd replace that resistor. Then I look at the case of the device which is painted white and I notice 2 big brown blotches and this fried component jumps out at me.
    I think it's a diode possible a reverse voltage protection or over voltage protection diode I'm not sure. Its connected between the poles of the power plug. Its connected to the power switch and the power terminal. It says on it AXJ 82 with an "S" with the diode symbol in the middle of the "S" The part is LxWxH 5x3x3 mm. I obviously need to replace this component but I'm not sure what it is. A Google search of AXJ 82 brings me to this page http://www.s-manuals.com/smd/82 its a schottky diode which makes sense. But I'm not sure.
  2. Robert_fay
    Robert_fay
    124
    34
    Jun 15, 2017
    Braeden Hamson likes this.
  3. Braeden Hamson
    Braeden Hamson
    199
    13
    Feb 18, 2016
    Awesome thank you! I'm curious how you tracked it down
  4. Robert_fay
    Robert_fay
    124
    34
    Jun 15, 2017
    I used a google search looking for Diode marking AXJ. and then looked through the TSC recognizing their symbol. I work for Digi-Key and spend a lot of time helping people identify parts and crosses so I get a lot of practice.
    Braeden Hamson and hevans1944 like this.
