B
Bob La Londe
Ok... what is the smallest rig that will weld continuously for atleast a
couple feet without getting hot and shotting down or getting hot not welding
well?
I've got a little flux core wire feed from Harbor Freight, and on a ncie day
like today, I can weld about 3-6 inches on 1/8 to 1/34 cold rolled before it
starts to spatter. At that point no adjustment works, and if I do push it a
little further the thermal overlaod kicks it off anyway.
I don't really have a problem with that, except that it takes forever to
cool down enough to weld good again.
I need something better. Yeah, I know you get what you pay for. I just
don't know if I can swing 2 or 3 grand for a really nice rig. I do have a
regulator and mix bottle already, and I've tried it with this little 110
welder. It makes a slightly cleaner weld than the flux core, but t doesn't
weld any further before shutting down, and I use this little toy in a lot of
places where lugging the bottle around just isn't practical. As a result I
just leave a big spool of flux core in the unit and use it.
Anyway, when (not if) I get a bigger rig with a longer duty cycle it will
not totally replace the little carry box. I will still need it
occassionally in the field.
Heck, I'm rambling and letting my welder cool down so I can finish my
project. So what's the smallest unit you would get if you wanted a really
high duty cycle? Seems I weld a lot of 1/8 upto 1/4" cold rolled. Rarley,
but occassionally 3/8.
I've got outlets wired for 30amp and 50amp equipment in my shop, and by the
overhead doors so I can work outside.
well?
