S
Saran
This also addresses a message I posted a couple of days ago. I am
trying to design an analog switch for a DRAM application.
The problem is "a drastic difference" in behavior when I used cadence
tool to pspice. My schematic is a very simple test circuit where the
gate of an NMOS is made logic low (-3 V). I am putting a value 100mV on
one end of the NMOS switch (say, drain). A capacitor is connected to
the other side of the switch with a value 1pF. Now, the problem is
that, when I run transient analysis, I am seeing a voltage of about 90+
mV on the capacitor net. How is this possible? The transistor is turned
off and I should ideally not see anything except leakage.
This was the issue when I used spectre simuation in cadence. I did the
same experiment using Orcad pspice and it works as I expect it to.
Before I was working with pspice, I thought it might be a leakage
problem associated with the internal diode inside the MOSFET and to
check that out, I put a transistor whose gate was connected to inverse
clock, before the capacitor. In this setup, if the main transistor is
on, then the other transistor is off. I did this to provide a low
impedence path to the leakage, if any. So, when the main transistor or
the switch is off, any leakage may flow through this low impedence path
created by the second transistor and if the switch is on, the second
transistor functions as open circuit and should not affect my circut.
This setup works.
I am really surprised because, this logically baffles me. Further, how
come Pspice gives me a different behavior (which I believe to be
correct) in the first case?
Any help is greatly appreciated. I hope I have posed the question
clearly.
Regards,
Saran
This setup works.
clearly.
Regards,
Saran
