Weird diff amp behavior?
S
Sam
hey,
i'm using a LM324 opamp configured as a diff amp. the inputs come
from opamp followers, so there shouldn't be any loading issues.
when i vary the input connected to the inverting (-) terminal
everything's fine - i see a clear change in the differential output.
but when i vary the input connected to the non-inverting (+) terminal
there's no change in the output. any ideas? (fyi, diff gain is
currently 4.7 [470s over 100s])
thanks so much!,
sam
E
Eeyore
How about posting a circuit diagram so as to check it's right ?
Are any inputs close in voltage to the power supply voltages btw ?
Graham
S
Sam
yep - i forgot to use a split supply, so it was trying to drive the
output below 0 when there was no way that was possible! thanks!
-sam
E
Eeyore
It's nice when there's a simple answer ! ;~)
Graham
