T
tempus fugit
Hey all;
I posted a message on this topic a few days ago (pops problems when preamp
is turned on). I've done a little more experimenting, and found these
results:
1. When I switch the mic preamp on, I get a little (1 volt or so) pop. I
assume this is pretty normal, and not much of a problem. Someone answered
with some great ideas for a mute circuit, which I'm sure will solve the
problem.
2. (this is the biggy) When I turn the phantom power switch on, I get a big
(10 - 15v) DC blast at the output. If I probe the actual output pin (i.e.
before the DC blocking cap) this DC voltage remains for several seconds.
3. When I turn the phantom power switch off, I get another big (-15v) DC
blast at the output. Again, it remains there for several seconds at the
output pin of the IC I'm using, but drops away fairly quickly at the output
jack (post DC blocking cap).
4. Both 2 and 3 only happen with a mic connected - there is virtually no DC
pop (<1v) with no mic connected. Also, there is a brief DC pulse at the
inputs (with a mic connected) of similar size, but it disappears quickly.
There are DC blocking caps at the inputs. Where is all this DC voltage
coming from? Any suggestions as to how to get rid of it?
results:
problem.
