Weeder Freq Counter
Discussion in '8bit Microcontrollers' started by Fred, Jul 20, 2006.
  1. Fred
    Fred Guest
    I have been trying to get the weeder program to operate on a 16F628A chip in
    its basic form with register locations changes as appropriate . The program
    shows on the display / / . / / / / / MHz with a regular flash to Overflow
    in approximately 30 seconds.In MpLab the only noticable difference between
    simulations ( F84 - F628A ) is that the second run of the program does not
    set INDF back to its starting value of 2F. Before I smash the darn thing can
    anybody offer any suggestions . Signed most frustrated
  2. Hopkins
    Hopkins Guest
    lol sounds like my projects :)
  3. NewsGroup
    NewsGroup Guest
    Have you turned off the comparators.
    movlw 7
    movwf CMCON
    Mike.
  4. Fred
    Fred Guest
    Thanks for the reply Mike . yes , sorry I didnt mention that I had done so
    .. Talking to a mate at work today , the direction of conversation was
    tending to a fault with MpLad , with an associated assembler to hex fault .
    The hammer is raising
  5. Joe
    Joe Guest
    I did a conversion to a 16F628 a couple of years ago, so I'm including the
    code in the hope you can get something out of it.
    There are two files below - the first (main.asm) with the actual code for
    the frequency counter and the second (delay.inc) with some delay functions.
    Note: I used a 20 MHz x-tal, so you might need to change the timing in the
    delay routines. Also, I changed the display code to handle a HD44780 based
    LCD display. I think the original weeder used a similar display, but the
    display timing in the Peter Cousens or Terry Weeder code is way off from the
    timings stated in the datasheets for HD44780 based displays.
    Hope this helps!
    Best regards,
    Johnny
    ; FREQUENCY COUNTER
    ; Model : WTCNT
    ; Author : Terry J. Weeder
    ; Date : November 18, 1993
    ; Version: 1.0
    ; WWW.WEEDTECH.COM
    ; Ported to 16f84 by
    ; Peter Cousens
    ; October 1998
    ; Cleaned up and ported to 16F628 by
    ; Rewritten LCD output code to 1x16 display organized as 2x8
    ; Johnny Norre
    ; March 2004
    ;watchdog disabled
    list P=16F628
    include "P16f628.inc"
    __CONFIG _CP_OFF & _XT_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF & _BODEN_OFF &
    _MCLRE_OFF
    MSB equ 7h
    LSB equ 0h
    cnt equ 2h
    rs equ 2h
    rw equ 1h
    e equ 0h
    o equ 7h
    VAR_BASE = 0x20 ; Base of general purpose registers
    gate equ 00h+VAR_BASE
    cnt1 equ 01h+VAR_BASE
    cnt2 equ 02h+VAR_BASE
    cnt3 equ 03h+VAR_BASE
    calc1 equ 04h+VAR_BASE
    calc2 equ 05h+VAR_BASE
    calc3 equ 06h+VAR_BASE
    sum1 equ 07h+VAR_BASE
    sum2 equ 08h+VAR_BASE
    sum3 equ 09h+VAR_BASE
    rtcc2 equ 0Ah+VAR_BASE
    Disp1 equ 0Dh+VAR_BASE
    Disp2 equ 0Eh+VAR_BASE
    Disp3 equ 0Fh+VAR_BASE
    Disp4 equ 10h+VAR_BASE
    Disp5 equ 11h+VAR_BASE
    Disp6 equ 12h+VAR_BASE
    Disp7 equ 13h+VAR_BASE
    Disp8 equ 14h+VAR_BASE
    count1 equ 20h+VAR_BASE
    count2 equ 21h+VAR_BASE
    in_reg equ 22h+VAR_BASE
    addcnt equ 23h+VAR_BASE
    DelayTmp
    DelayTmpLo equ 24h+VAR_BASE
    DelayTmpHi equ 25h
    CharPos equ 26h ; 0..7 = left side, 8..15 = right side
    LcdTmp equ 27h
    oflag equ 28h+VAR_BASE ; Added - original code used IRP bit in the STATUS
    register (not portable!)
    org 0
    goto start?
    #include "..\MultiThermometer\delay.inc"
    ; LcdCtrlOut
    ; Sends a control code to the LCD
    ; Input:
    ; Wreg = control code to send
    ; Output:
    ; None
    ; Modified:
    ; Wreg
    ; STATUS - changed to bank 0 on exit
    LcdCtrlOut:
    clrf STATUS
    movwf PORTB ; Write to port B
    call Delay1Ms
    bcf PORTA,rs ; CLear RS flag = instruction output
    bsf PORTA,e ; Set E flag
    call Delay1Ms
    bcf PORTA,e ; Clear E flag = buffer data
    call Delay1Ms
    return
    ; LcdCharOut
    ; Sends a character to the LCD
    ; Input:
    ; Wreg = character to send
    ; Output:
    ; None
    ; Modified:
    ; Wreg
    LcdCharOut:
    clrf STATUS
    movwf LcdTmp ; Store character (Wreg)
    movf CharPos,W ; Get address
    addlw 0x80 ; Point to left side of display
    btfsc CharPos,3 ; Should it be right side?
    addlw 0x38 ; Point to right side of display
    call LcdCtrlOut
    movf LcdTmp,W
    call Delay1Ms
    bsf PORTA,rs ; Set RS flag = data out
    call Delay1Ms
    call Delay1Ms
    incf CharPos,1 ; Point to next character position
    return
    sub:
    bcf oflag,o ;clear overflow bit
    movf calc1,w ;subtract calc1 from cnt1
    subwf cnt1 ,f
    btfsc STATUS,C
    goto sb1
    movlw 0x01 ;borrow from cnt2 if overflow
    subwf cnt2 ,f
    btfsc STATUS,C
    goto sb1
    subwf cnt3 ,f ;borrow from cnt3 if cnt2 overflow
    btfss STATUS,C
    bsf oflag,o ;set overflow bit if result is negative
    sb1:
    movf calc2,w ;subtract calc2 from cnt2
    subwf cnt2 ,f
    btfsc STATUS,C
    goto sb2
    movlw 0x01 ;borrow from cnt3 if cnt2 overflow
    subwf cnt3 ,f
    btfss STATUS,C
    sb2:
    movf calc3,w ;subtract calc3 from cnt3
    subwf cnt3 ,f
    btfss STATUS,C
    retlw 0x00
    add:
    movf calc1,w ;add calc1 to cnt1
    addwf cnt1 ,f
    btfss STATUS,C
    goto ad1
    incfsz cnt2 ,f ;add to cnt2 if cnt1 overflow
    goto ad1
    incf cnt3 ,f ;add to cnt3 if cnt2 overflow
    ad1:
    movf calc2,w ;add calc2 to cnt2
    addwf cnt2 ,f
    btfsc STATUS,C
    movf calc3,w ;add calc3 to cnt3
    addwf cnt3 ,f
    retlw 0x00
    cnvt:
    movlw 0x07 ;7 digits in display
    movwf count1
    movlw Disp1 ;set FSR for MSB in display
    movwf FSR
    movlw 0x2F ;one less that ASCII "0"
    cnvt0:
    movwf INDF
    incf FSR ,f
    decfsz count1 ,f
    goto cnvt0
    movlw 0x0F ;load "1,000,000" in calc1-3
    movwf calc3
    movlw 0x42
    movwf calc2
    movlw 0x40
    movwf calc1
    cnvt1:
    call sub ;subtract number from count
    incf Disp1,f ;increment 1,000,000's register
    movlw 0x3A
    xorwf Disp1,w
    btfsc STATUS,Z
    goto overflow
    btfss oflag,o ;check if overflow
    goto cnvt1
    call add ;add back last number
    movlw 0x01 ;load "100,000" in calc1-3
    movwf calc3
    movlw 0x86
    movwf calc2
    movlw 0xA0
    movwf calc1
    cnvt2:
    incf Disp2,f ;increment 100,000's register
    goto cnvt2
    clrf calc3 ;load "10,000" in calc1-3
    movlw 0x27
    movwf calc2
    movlw 0x10
    movwf calc1
    cnvt3:
    incf Disp3 ,f ;increment 10,000's register
    goto cnvt3
    movlw 0x03 ;load "1,000" in calc1-3
    movwf calc2
    movlw 0xE8
    movwf calc1
    cnvt4:
    incf Disp4 ,f ;increment 1,000's register
    goto cnvt4
    clrf calc2 ;load "100" in calc1-3
    movlw 0x64
    movwf calc1
    cnvt5:
    incf Disp5 ,f ;increment 100's register
    goto cnvt5
    call add ;add back number
    movlw 0x0A ;load "10" in calc1-3
    movwf calc1
    cnvt6:
    incf Disp6 ,f ;increment 10's register
    goto cnvt6
    movf cnt1,w ;put remainder in 1's register
    addwf Disp7 ,f
    incf Disp7 ,f
    retlw 0x00
    count:
    clrf STATUS
    bsf STATUS,RP0 ; Bank 1
    errorlevel -302
    movlw b'00110111' ;rtcc = ext, 1/256
    movwf OPTION_REG
    errorlevel +302
    bcf STATUS,RP0 ; Bank 0
    bcf PORTA,3
    bcf PORTA,2
    clrf cnt3
    clrf TMR0
    clrf rtcc2
    bsf PORTA,2 ;toggle rtcc pin
    bcf PORTA,2
    movf gate,w ;get gate time
    movwf count1
    bsf PORTA,3 ;start count
    fr4:
    movlw 0xFA
    movwf count2
    goto fr6
    fr5:
    nop
    nop
    nop
    nop
    nop
    nop
    fr6:
    movf TMR0,w ;test for rtcc rollover (12)
    subwf rtcc2 ,f
    btfss STATUS,Z
    goto fr7
    nop
    goto fr8
    fr7:
    btfsc STATUS,C
    incf cnt3 ,f
    fr8:
    movwf rtcc2
    nop
    nop
    nop
    decfsz count2 ,f
    goto fr5
    decfsz count1 ,f
    goto fr4
    bcf PORTA,3 ;stop count
    movf TMR0,w ;get rtcc count
    movwf cnt2
    subwf rtcc2 ,f ;test for rtcc rollover
    btfss STATUS,C
    goto fr9
    btfss STATUS,Z
    incf cnt3 ,f
    fr9:
    clrf cnt1 ;set to get prescaler count
    fr10:
    decf cnt1 ,f
    bcf PORTA,2
    movf TMR0,w ;test if rtcc has changed
    xorwf cnt2,w
    btfsc STATUS,Z
    goto fr10
    retlw 0x00
    ; START
    start?:
    clrf PORTA
    ; Turn off comparators and enable PORTA for input/output
    movlw 0x07
    movwf CMCON
    clrf STATUS
    errorlevel -302
    movlw b'00010000' ;instruction, write, enable low
    movwf TRISA
    errorlevel +302
    clrf PORTB
    clrf STATUS
    errorlevel -302
    movlw b'00000000'
    movwf TRISB
    errorlevel +302
    movlw .15 ; Wait 15 ms.
    call DelayMs
    movlw 0x38 ;initialize display
    movwf PORTB
    bsf PORTA,e ;toggle enable
    call Delay1Ms
    bcf PORTA,e
    call Delay1Ms
    call Delay1Ms
    bcf PORTA,e
    call Delay1Ms
    call Delay1Ms
    bcf PORTA,e
    call Delay1Ms
    movlw 0x38 ;function
    call LcdCtrlOut
    movlw b'00001100' ;display on, cursor off
    call LcdCtrlOut
    movlw b'00000001' ;clear display
    call LcdCtrlOut
    movlw b'00000110' ;entry mode
    call LcdCtrlOut
    call Welcome
    mhz:
    movlw 0x14 ;0.1 sec gate
    movwf gate
    call count
    call cnvt ;convert binary to BCD
    movlw 0x30 ;test if "0"
    xorwf Disp1,w
    btfss STATUS,Z
    goto mhz1
    xorwf Disp2,w
    btfsc STATUS,Z
    goto khz1
    mhz1:
    clrf CharPos ;Output from left side
    movlw 0x02 ;output first 2 characters
    movwf count1
    movlw Disp1 ;MSD of freq
    movwf FSR
    mhz2:
    xorwf INDF,w
    btfss STATUS,Z
    goto mhz3
    movlw 0x20 ;change preceeding "0's" to "space"
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto mhz2
    goto mhz4
    mhz3:
    movf INDF,w
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto mhz3
    mhz4:
    movlw 0x2E ;"."
    call LcdCharOut
    movlw 0x05 ;output last 5 characters
    movwf count1
    mhz5:
    movf INDF,w
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto mhz5
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x4D ;"M"
    call LcdCharOut
    movlw 0x48 ;"H"
    call LcdCharOut
    movlw 0x7A ;"z"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    goto mhz
    khz:
    movwf gate
    call count
    movlw 0x30 ;test if 0
    xorwf Disp1,w
    btfss STATUS,Z
    goto mhz1
    movlw 0x32 ;test if < 2
    subwf Disp2,w
    btfsc STATUS,C
    goto mhz1
    xorwf Disp2,w
    btfss STATUS,Z
    goto khz1
    xorwf Disp3,w
    btfsc STATUS,Z
    goto xkhz
    khz1:
    movlw 0x05 ;output first 5 characters
    movwf count1
    movwf FSR
    khz2:
    xorwf INDF,w
    btfss STATUS,Z
    goto khz3
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto khz2
    goto khz4
    khz3:
    movf INDF,w
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto khz3
    khz4:
    movlw 0x2E ;"."
    call LcdCharOut
    movf INDF,w ;output last 2 characters
    call LcdCharOut
    incf FSR ,f
    movf INDF,w
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x4B ;"K"
    call LcdCharOut
    movlw 0x48 ;"H"
    call LcdCharOut
    movlw 0x7A ;"z"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    goto khz
    xkhz:
    movlw 0xC8 ;1 sec gate
    movwf gate
    call count
    xorwf Disp1,w
    btfss STATUS,Z
    goto khz
    subwf Disp2,w
    btfsc STATUS,C
    goto khz
    xorwf Disp2,w
    btfss STATUS,Z
    goto xkhz1
    xorwf Disp3,w
    btfsc STATUS,Z
    goto hz0
    xkhz1:
    movlw 0x04 ;output first 4 characters
    movwf count1
    movwf FSR
    xkhz2:
    xorwf INDF,w
    btfss STATUS,Z
    goto xkhz3
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto xkhz2
    goto xkhz4
    xkhz3:
    movf INDF,w
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto xkhz3
    xkhz4:
    movlw 0x2E ;"."
    call LcdCharOut
    movf INDF,w ;output last 3 characters
    call LcdCharOut
    incf FSR ,f
    movf INDF,w
    call LcdCharOut
    incf FSR ,f
    movf INDF,w
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x4B ;"K"
    call LcdCharOut
    movlw 0x48 ;"H"
    call LcdCharOut
    movlw 0x7A ;"z"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    goto xkhz
    hz:
    movwf gate
    call count
    xorwf Disp1,w
    btfss STATUS,Z
    goto xkhz1
    xorwf Disp2,w
    btfss STATUS,Z
    goto xkhz1
    subwf Disp3,w
    btfsc STATUS,C
    goto xkhz1
    hz0:
    movlw 0x07 ;output first 7 characters
    movwf count1
    movwf FSR
    hz1:
    xorwf INDF,w
    btfss STATUS,Z
    goto hz2
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto hz1
    goto hz3
    hz2:
    movf INDF,w
    call LcdCharOut
    incf FSR ,f
    decfsz count1 ,f
    goto hz2
    hz3:
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x48 ;"H"
    call LcdCharOut
    movlw 0x7A ;"z"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    movlw 0x20 ;"space"
    call LcdCharOut
    goto hz
    overflow:
    movlw 0x01 ;clear display
    call LcdCtrlOut
    movlw 0x02
    movwf CharPos ;Output from char 2
    movlw 0x84 ;display address
    call LcdCtrlOut
    movlw 0x4F ;"O"
    call LcdCharOut
    movlw 0x76 ;"v"
    call LcdCharOut
    movlw 0x65 ;"e"
    call LcdCharOut
    movlw 0x72 ;"r"
    call LcdCharOut
    movlw 0x66 ;"f"
    call LcdCharOut
    movlw 0x6C ;"l"
    call LcdCharOut
    movlw 0x6F ;"o"
    call LcdCharOut
    movlw 0x77 ;"w"
    call LcdCharOut
    goto mhz
    Welcome:
    movlw 0x01
    call LcdCtrlOut
    clrf CharPos
    movlw "D"
    call LcdCharOut
    movlw "u"
    call LcdCharOut
    movlw "N"
    call LcdCharOut
    movlw "o"
    call LcdCharOut
    movlw " "
    call LcdCharOut
    movlw " "
    call LcdCharOut
    movlw "G"
    call LcdCharOut
    movlw "F"
    call LcdCharOut
    movlw "-"
    call LcdCharOut
    movlw "0"
    call LcdCharOut
    movlw "0"
    call LcdCharOut
    movlw "1"
    call LcdCharOut
    movlw 15
    call DelayDs
    return
    end
    --- < CUT> -------------------------------------------------------------
    ; *** DELAY.INC (C)2003 by DuNo Electronics I/S & Johnny Norre ***
    ; This module provides various delay functions. All functions assume
    ; a clock speed of 20MHz!
    ; NOTE: The variable "DelayTmp, DelayTmpLo and DelayTmpHi" (2 bytes )
    ; must have been defined prior to calling any functions in this
    ; module. The DELAYVAR define can be used in a CBLOCK to define
    ; these variables.
    ; 26.04.03 v0.0 Initial version - DelayMS implemented
    ; --- Defines ---
    ; DELAYVAR can be used in a CBLOCK to define the variables needed by this
    module.
    ; Note: DELAYVAR must be defined in Bank 0!
    #define DELAYVAR DelayTmp:0, DelayTmpLo, DelayTmpHi
    ; --- Functions ---
    ; DelayMs
    ; Delay for 1..256 milliseconds
    ; Note: The time spent in this function is not included in the
    ; timing, resulting in a small overhead (3 cycles per
    ; millisecond).
    ; Input:
    ; Wreg = Number of milliseconds (0 = 256)
    ; Output:
    ; None
    ; Modified:
    ; Wreg and DelayTmpLo is modified by function
    DelayMs:
    clrf STATUS ; Bank 0
    bcf STATUS,RP1
    movwf DelayTmpLo
    DelayMsLoop:
    call Delay1Ms
    decfsz DelayTmpLo,f
    goto DelayMsLoop
    return
    ; DelayDs
    ; Delay DeciSeconds - Delay for 1..256 * 1/10 seconds
    ; timing, resulting in a small overhead.
    ; Input:
    ; Wreg = Number of deciseconds (0 = 256)
    ; Output:
    ; None
    ; Modified:
    DelayDs:
    movwf DelayTmpHi
    DelayDsLoop:
    movlw .100
    call DelayMs
    decfsz DelayTmpHi,f
    goto DelayDsLoop
    return
    ; Delay1Ms
    ; Delay for 1 millisecond. This is done by waiting for 5000 cycles
    ; as the module assumes 20MHz clock speed.
    ; Input:
    ; None
    ; Output:
    ; None
    ; Modified:
    ; Wreg
    Delay1Ms:
    movlw .256-.50+2 ; Burn 50*100 cycles (minus time spent by this function)
    Delay1MsLoop:
    call Delay100Cycles
    addlw 1
    btfss STATUS,Z
    goto Delay1MsLoop
    goto $+1
    return
    ; Delay100Cycles
    ; Delay for 100 cycles.
    ; Note: 2 cycles is spent by the call to the funtion and
    ; another 2 by returning to the caller, so 96 cycles
    ; is spent by the actual code in the function
    ; Input:
    ; None
    ; Output:
    ; None
    ; Modified:
    ; None
    Delay100Cycles:
    call Delay16Cycles
    call Delay16Cycles
    call Delay16Cycles
    call Delay16Cycles
    call Delay16Cycles
    call Delay16Cycles
    return
    ; Delay16Cycles
    ; Delay for 16 cycles
    ; Note: Call to the function takes 2 cycles and the return
    ; takes 2 cycles, so 12 cycles is spent by the function
    ; Input:
    ; None
    ; Output:
    ; None
    ; Modified:
    ; None
    Delay16Cycles:
    goto $+1 ; Spend 2 cycles
    goto $+1 ; spend 2 cycles
    return
  6. Fred
    Fred Guest
    Thanks Joe , as you noted in your conversion " original code used IRP bit in
    the STATUS register (not portable!)" .When I watched the program run in
    MPlab the program went to update its latest converted figure in the
    allocated FSR but the value in the INDF register just seemed to vanish . It
    , of course , was directed to a different bank .
    A smile appears , the hammer gently lowered , all is calm till the next
    project.
