Jim Thompson said:
I've got outdoor lights (12VAC) that use wedge base sockets. Only
problem is the lamps seem to disintegrate in the heat and break off
when you try to change the bulb.
(1) Any Tricks to get the !@#$%&* glass out of the socket?
(2) Alternative socket and bulb style that's small like that?
...Jim Thompson
I have experienced this issue a multiple of times on exterior landscape type
fixtures. My first impression was that it would be near impossible to
construct the sockets, or the fixtures, out of a lower quality material.
The solutions I've tried that appear to work are:
1) Changed from an 11 watt lamp to a 7 watt lamp to reduce the heat issues.
2) Buffed & coated the contacts on the lamp with a silicone spray to reduce
corrosion, and the resulting removal difficulty.
3) Gently move the burned out lamp from side to side (helps to break the
lamp loose from any welded, or seized contacts) before attempting to remove
it.
4) Replace any of the sockets with loose, or low tension contacts, that
allow arcing to take place.
Since taking these actions it's been years since I've had a lamp break on
removal.
For the lamps that broke on removal I constructed a pick to help remove the
broken lamp base. It consisted of a thin piece of flat spring steel (street
cleaner brush) with a short hook bent on the end, and ground down to fit
into the socket. This allowed the hook to be slipped in along the side of
the lamp, and pull it out. A small pair of Hemostats (like a medical person
would use) also works.
Louis--
Remove the two fish in address to respond
