H
henry b
I'm trying to sort out a tuning problem with a philips 28pw6005 tv.
there are no problems with AV inputs, but the picture through the
aerial is very weak - it just about picks up a signal (poor picture
with ok audio) from the cable box, ie the strongest signal. Its not
the signal because i've checked it with another tv and is fine.
Having opened the box, i see underneath the tuner (silver shielded
unit with aerial connector on outside) there is a little brown mess.
As the tuner is working weakly would unsoldering and then resoldering
the tuner unit solve this problem?? - ie its a solder connection
problem?
I've got the numbers/letters off the tuner but not sure if this would
be any help?
thanks for any ideas/advice,
henry.
problem?
be any help?
henry.
