We have to interface load cell with Plc
Discussion in 'General Electronics Discussion' started by balajiraja, Feb 24, 2017.
  1. balajiraja
    balajiraja
    Feb 24, 2017
    We have to interface load cell with Plc. So, We need converter circuit for that. Please suggest us circuit diagram or IC for that conversion.
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Here you go!
    If you can be a bit more specific about what you want to do then we may be able to help further. At the moment it's the best I can do. Hope this helps.
    Adam
  3. garublador
    garublador
    111
    43
    Oct 14, 2014
    Depending on the PLC, there might be a module you can just purchase to interface with a load cell.
    Otherwise, I'd start with Googling, "load cell amplifier". Without more specifics we can't do any better than that.
  4. Minder
    Minder
    3,115
    666
    Apr 24, 2015
    Check to see if your manuf of PLC has a 4-20ma add on module or unit.
    Most load cells use this communication method.
    M.
  5. ICPDASUSA
    ICPDASUSA
    4
    3
    Sep 2, 2014
  6. Minder
    Minder
    3,115
    666
    Apr 24, 2015
    I was thinking more on the lines of the manuf add-on that would be an expansion module of the PLC, many manuf offer different option modules for different interface solutions, this then communicates directly with the PLC memory.
    M.
