Waveform simulation in LTspice
Discussion in 'General Electronics Discussion' started by RATAN ROY, Jan 13, 2016.
  1. RATAN ROY
    RATAN ROY
    4
    Jan 13, 2016
    Hi All,
    I am trying to generate transient waveform using LTspice exponential voltage source. I am not able achieve the desired waveform. Can anybody help me how to get desired waveform. My desired waveform is as below with T1 = 40 microseconds and T2=120 microseconds. At T2 Voltage amplitude should be 50% of peak voltage amplitude
  2. Alec_t
    Alec_t
    2,910
    791
    Jul 7, 2015
    Welcome to EP!
    Does i/v mean
    1) i divided by v
    2) i OR v
    Is the rounded top to the waveform essential, or would a conventional RC charge/discharge waveform do?
    Edit: The nearest I could get to the first waveform was by setting the source properties as EXP(0 1 0 40u 40u 80u)
  3. Harald Kapp
    10,820
    2,440
    Go to our resources -> simulators -> LTSPICe, you'll find useful information there, including surge pulses as shown above.
    The latter. This is a typical surge waveform as described in various standards.
    The exact waveform is imho not that critical. The relevant point are 100% at T1 and 50% T2 with an exponential decay after T=T1. This waveform is typically generated in a test generator by a combination of RLC elements and switches. It is furthermore coupled to a device under test via coupling networks consisting of RLC eleme´nt themselves. It would be moot to try to synthesize the waveform in more detail, especially considering that the real test more often than not reveals effects that could not be simulated simply because they were unknown at the time of simulation (e.g. stray capacitances from wiring and/or PCB traces).
  4. LvW
    LvW
    604
    146
    Apr 12, 2014
    The requested transient waveform is a typical step response of a low-Q second-order bandpass.
    So - it shouldn`t be a problem to create such a signal.
    Arouse1973 likes this.
  5. RATAN ROY
    RATAN ROY
    4
    Jan 13, 2016
    My thought is also same with you. May be some RLC network needs to be added with appropriate voltage source. Hopefully by changing RLC value we can control T1 & T2 as required. Since I am new in this waveform simulation need your help to generate waveform and perform simulation.
    Can we do cable modelling as well in LTspice? Would be appreciated if some reference materials can be provided.
  6. LvW
    LvW
    604
    146
    Apr 12, 2014
    Ratan - didn`t you read my answer? A simple RC-CR bandpass will do the job to transfer a step signal into the desired waveform .
    The example provided with my anser is a RC lowpass (1k, 16nF) in series with a CR highpass (16n, 100k).
  7. RATAN ROY
    RATAN ROY
    4
    Jan 13, 2016
    I would definitely try with the info you provided. I believe I need to take pulse voltage source with above mentioned elements added in schematic. Thank you so much.
  8. LvW
    LvW
    604
    146
    Apr 12, 2014
    Of course, you must tune the parts values according to your timing requirements (T1 and T2).
  9. Harald Kapp
    10,820
    2,440
    The complete description of how to simulate your waveform is in my LTSPICE ressource. Did you even care to look it up as suggested in post #3? You can directly set the peak voltage and the timing parameters.
  10. RATAN ROY
    RATAN ROY
    4
    Jan 13, 2016
    I have tried to generate same waveform here. Played around with component value to achieve desired T1 (40us) and T2 (120us). T2 needs to be considered at 50% of peak amplitude. It sounds I achieved T1 but not T2 yet. One more thing I observed is peak amplitude is significantly reduced 600V to 357V. The max I got T2 at 50% of peak amplitude is about 89us.
    Here I attached my experimental schematics. Look forward for your help. I would be glad if you can provide some references on cable modeling in LTspice that would be great. I want to study that too. Surge waveform generation.JPG Waveform Generation_1.JPG
