Wave Trap
Discussion in 'Electronic Basics' started by Dave.H, Mar 30, 2008.
  1. Dave.H
    Dave.H Guest
    I have an old tube regenerative radio, but where I live, there's a
    powerful radio station that overpowers the other weaker stations, I
    want to build I wave trap, already have a 2 gang variable capacitor
    sitting around, unknown value, that maybe I could use. Is there any
    way I can measure this using the capacitance feature on my
    multimeter? What size coil wire would I need?
    Thanks, Dave
  2. Tom Biasi
    Tom Biasi Guest
    Hi Dave,
    You certainly could measure it with your capacitance meter.
    The coil that you would need would depend on the frequency.
    You could look into "LC Resonant circuits"
    However, it is unlikely that you can achieve the desired result this way.
    The regen circuit is very sensitive and high gain across the entire band.
    To trap a powerful signal with just one LC circuit is not likely.
    Tom
  3. Dave.H
    Dave.H Guest
    The frequency of the overpowering radio station is 1431 kHz (we have 9
    kHz spacing in Australia), found a wave trap kit at Antique Electronic
    Supply I might try, Cat # K-934
