? watts through a #6 wire
Hi guys & Gals;
As mentioned before father and I have come to an agreement, I can
mount my apanels on the garage. The wire run from the garage will be
about 100 to 120 feet, I have #6 wire (already installed) and I was
wondering, how much current (at 12 volts) can I safely put through my
wire before resistance becomes an issue?
I only have 290 watts right now but I will be adding 2 more 50 watt
panels each month until November.
Should I switch to a 24 volt system, which would also help with line
loss.
Any advice would be greatly appreceated, and keep smilin'
Glenn
PS. The roof is about a 35 degree angle, so I was wondering, what
about snow?
G
Gary
Hi guys & Gals;
loss.
Glenn
about snow?
The resistance of #6 COPPER wire is 0.403 ohm per 1000 ft,
So the resistance of your run (roundtrip) is:
(0.403) ((120 + 120)/1000) = 0.097 ohm
The current for 290 watts at 12V is 290/12 = 24.2 amps
The voltage drop is:
E = IR = (24 amp) (0.097 ohm) = 2.3 Volts (or about 20% of 12V)
I don't know much about PV panels, but 20% seems like a lot to give up?
The voltage drop would increase linearly with current, so 580 watts of
panels would give a voltage drop of 4.6 Volts ... etc
Since #6 TW wire is only rated for about 55 amp, I think you would also
have a safety issue before all of your panels are in.
You probably need bigger wires, and/or a panel connection that gives a
much higher output voltage.
On the roof slope, I have a 45 deg south facing slope in snow country,
and it does not accumulate snow -- it melts off soon after snowfalls.
The North and East slopes do accumulate quite a bit of snow.
Gary
S
SQLit
Hi guys & Gals;
loss.
Glenn
about snow?
When dealing with dc voltages, I use MTW or welding cable. Machine tool wire
is a lot finer strands and tends to carry a tad better than regular stranded
wire. Welding or locomotive cable is by far the best you can get. Also the
most expensive. I think you should really start considering increasing the
wire size and going to a higher voltage.
Hi Guys & Gals;
While I might not understand all the advice (still learning and loving
it), would it be better if I put my batteries, regulater and inverter
in the garage and ran a line from my inverter into my house? Could I
use the #6 (copper) wire that I already have installed. Just a
thought.
Once again, thanks for the advice and keep smilin'
Glenn
