B
Bobby
I need advise on the following:
The device I am making will use this FET as an output. The device will
operate in the range 12 - 24 volts, depending on the users requirement to
illuminate a few light bulbs.
The FET I want to use can handle up to 16 amps at a max of 100v.
I want to suggest the recommended operating current not exceed 1 amp. as the
FET heats up considerably over 1 amp, and due to space restrictions a
heatsink is not possible.
At 24 volts that would be 24 watts, and at 12 volts that would be 12 watts.
How do I label this device so that a lay person will understand its maximum
operating capacity should not exceed 1 amp, depending on their selected
operating voltage?
Most lay users seem to look at wattage and assume that the indicated wattage
is for 12 or 24 volt operation.
Any suggestion appreciated.
operating voltage?
