A
andy
OK, my first thoughts are that it could be implemented with one cheap
chip, along the lines shown here:
http://www.terrypin.dial.pipex.com/Images/Greenhouse1.gif
thanks, that's quite neat.
some more thoughts.
the holdoff is a period during which the system won't retrigger. But
having some hysteresis on the input side might be enough for this. I think
some kind of RC circuit is needed on the input side to stop it triggering
on things like someone casting a shadow on the sensor though.
if i use this, i'll have to change the resistor values a bit - the overall
current needs to be kept right down so it can run from a small solar panel.
i like the way you've made the schmitt trigger and brought out inverting
and noninverting signals from it without any extra gates. also the diodes
on the nor gate outputs to make an OR gate.
overall it's a lot simpler than my design, so maybe i need to think about
why i was making it so complex.
some more thoughts.
All this is to operate your daily tank-dumper?andy said:sorry, i re-did it and then forgot to change the link. it should be:
http://www.niftybits.ukfsn.org/electronics/daily-water-with-chip-bw.png
I'd use a $3.95 coffee timer. ;-)
Cheers!
Rich
after the comments on my first version, i've redesigned the circuit using
CMOS ICs and a mosfet to switch the coil. I was meaning to get it working
before i posted the new design, but i'm waiting for some parts, so i'm
posting it now to see what people think. as before, i would appreciate any
comments on how i've done it.
mostly what i want to know is if there's
anything that will stop it working the way i'm expecting, cause parts to
fail, cause a hazard, or if i've missed any obvious simplifications to the
design i've come up with. it's a bit more complex than before, because
i've added a feature to water in the morning, evening or both.
I've tested the part of the circuit that gets the light on/off signal from
the LDR using the 393, and xors it with the 'force watering' switch
signal, but then a chip failed and i'm waiting to get another one.
http://www.niftybits.ukfsn.org/electronics/daily-water-with-chip.jpg
http://www.niftybits.ukfsn.org/electronics/daily-water-with-chip.png
if you still think it's junk then say so, but i'd like to know why.
what's one of them? how? can you run it off a small solar panel?
A *small* solar panel is going to drive that solenoid? You must be a
giant
What about the evening watering?
Oopps, sorry, no. They plug into the wall. It's just a 24-hour clockandy said:what's one of them? how? can you run it off a small solar panel?
From what I've read, "soft iron" is good for electromagnet cores. You couldandy said:The only bit I'm still stuck on is finding a good bit of metal for the
solenoid core - I have an old drain cover opener which works OK, but I
don't want to cut it if i can find something better, and none of the bolts
I've found are magnetic enough.
andy said:http://skullcap23.tripod.com/daily-water3-bw.png
http://skullcap23.tripod.com/daily-water3-bw.jpg
One thing i'm not sure about is whether i need the 2N3906 on the output,
or whether i could drive the MOSFET directly from the 4538 monostable's
outputs if i used the noninverting outputs and put the diodes the other
way round.
motor that turns a wheel with selectable on/off detents.
Glad to hear that you've got the thing going so well.
But it's still a lot of circuitry.
If it's solar powered, why do you need a timer? Aren't we all kinda
standing on one? ;-)
also look into transformer iron, or (I've read) silicon steel. You might
look in the yellow pages for metals recyclers and like that.
Keep the 2N3906. It gives a good solid pullup to drive the gate cap. This
is what you want, isn't it?
And, it looks like it waters either
A) by timer
B) when you push either button
or is there something I'm missing?
Is the 4538 just one-to-a-package? If so, you could lose
one of them by just oring the switches together.
Oh, don't use bolts. There's no such thing as a soft iron bolt.andy said:I know that, but when i go into B & Q looking for 'soft iron' bolts, i
can't find any.
Yeah, I know. I was just kind of thinking, well, isn't "there'sandy said:that's the point - it uses a photocell to detect morning/evening so as to
avoid problems with keeping a clock synchronised.
andy said:i am about 2 metres tall.
Maplin Electronics do a 50mA, 12V panel for £24.99 (Can probably get one
cheaper than this).
Which makes 600mW @12V.
A 10W panel gives 0.7Ah/day in uk winters, so 600mW gives 0.042 Ah/day.
Equals 1.75 mA ave. current. take off .75 mA for the electronics, and
there is 1mA*24*3600 = 86.4 Amp seconds for the solenoid.
I tested it last night, and it's pushing the magnet off the solenoid with
about 12A for well under a second, so this should be OK.
The point of the design i've come up with is that all that's needed to
start a watering cycle is a single very short pulse through the solenoid -
it doesn't need to hold a valve open for any length of time - just push a
permanent magnet off the end of the solenoid core.
electricity coming from the solar panels" a pretty good indication
that the sun's probably up? ;-)
Cheers!
Rich
It waters in the morning when one switch is set high, and in the evening
when the other one is. Moving the switches does trigger it, but that's a
side-effect.
