W
William P.N. Smith
Nelson Gietz said:I've been watering up the battery bank of golf cart batteries on my
system for the winter.
Was wondering how much to fill. The fillers are cylindrical, with two
slots up the sides. I've been filling 'til I see the miniscus... that is,
the water contacts the bottoms of the cylindrical tube. I'm assuming the
slots are "breathers" so when the water rises due to unreleased bubbles on
the plates, the H and O can still vent without burping too much water out.
That's all correct. [I'm assuming you aren't using these in golf
carts, as those sometimes overflow, and either need to be underfilled
or have Water Miser caps to prevent spillage.] I'm assuming you don't
do such agressive equalizing that your batteries are likely to
overflow...
Does anyone fill them higher than the bottom edge of the filler tube?
I'm looking at about 6 month intervals, so I don't have to put distilled
water in at below freezing temperatures.
I filled the golf cart batteries on my weather station up till the
slots were square, but with only 40W of panels I wasn't going to boil
them over. Now I use HydroCaps, and they barely lose any water at
all. [Hydrocaps can't be used for vigorous charging or equalizing,
but they work wonders for water conservation!]
