WANTED - Cermet trimmer top adj , 4.7 or 5k pin space 5mm x 10mm
Discussion in 'Electronic Repair' started by Graham, Oct 31, 2007.
  1. Graham
    Graham Guest
    Cermet trimmer top adj , 4.7 or 5k pin space 5mm x 10mm qty 2 ...
    So far no good ,
    Im trying to locate qty 2 (better 4) cermet trimer pot's , top adj ,
    value
    4.7 or 5 K ohm enclosed or open frame , pcb mount , pin space , 5 mm
    x 10
    mm
    The problem is , the pin spacing I need is , 5 mm by 10 mm . I can
    find any
    amount of 5 x 5 , rs components stopped stocking them last year .there
    range
    now jumps from 2k > 10k .., nothing on e-bay , maplin , only the small
    sizes
    Any suggestions , links or supply ?
    Tnx - Graham ..
