Wanted: bandpass filter design
P
Paul Burridge
Hi all,
I need a simple design for a BPF with a centre frequency of 17.2Mhz.,
corner frequencies one Meg or therabouts either side of that and a
reasonably good shape factor (nothing critical here). I don't mind
having to do a bit of tweaking of values myself if anyone has
something close to that they can post. Passive L/C combinations only,
please. (assume the usual 50R nominal Zs.)
p.
P
Peter O. Brackett
Paul:
[snip]
[snip]
Such a design can be achieved with a vert simple formula and a pocket
calculator or slide rule. Why don't you just use Bennett's simple formula
for the maximally flat approximation all pole element values, or Takashi's
simple formulae for the equiripple approximation all pole element values?
Oh... perhaps you want elliptic [Cauer or Darlington] designs or perhaps a
completely general parameter design in that case ypu will need a computer
and will need to do some programming or buy some programming, or
better yet...
Hire a consultant... :)
Hey, I've designed literally thousands of LC filters over decades in most
frequency ranges, for clients who have paid me well. I have access to very
sophisticated and comprehensive general parameter LC filter design
programs that I have written [In Fortran BTW] over lo these many years
and they are immediately at my disposal.
But... unfortunately for some... I never design filters for free!
I'll do it for you at my usual consulting rates.
My rates are reasonable. Just call or email me to discuss the terms and
conditions.
Peter
Professional Consultant - Signal Processing and Analog Electronics
Indialantic By-the-Sea, FL
peter dot brackett at "eye" triple "e" dot org.
USA area code three two one, number seven two three, nine two five five.
H
Harold E. Johnson
Conversely, go to the WB6BLD website and download the free student version
of Elsie and do it yourself, will take an hour to learn the software and 5
minutes to design the filter. Another good filter program that is free and
available and relatively easy to use is at the AADE website.
Would be worth your while to learn even if you seldom design a filter.
W4ZCB
Peter O. Brackett said:
Paul:
[snip]
[snip]
better yet...
conditions.
Peter
John Larkin
Hi all,
p.
The usual technique is to get a book that has tables of normalized LC
lowpass filters of various types, pick a response you like, and scale
it and map to a bandpass. Williams' "Electronic Filter Design
Handbook" has all this stuff.
It's mildly tedious, so I won't offer to do one for you.
John
Jeffrey Turner
Paul said:
Hi all,
If you have Office 2002 (XP), you can use this web site.
http://www.rfcafe.com/references/_spreadsheets/bp_butter_plot_ss.htm
A man, a plan, a cat, a canal - Panama!
Ho, ho, ho, hee, hee, hee
and a couple of ha, ha, has;
That's how we pass the day away,
in the merry old land of Oz.
M
maxfoo
Hi all,
p.
Try this 5 pole Chebychev with 0.1dB ripple
Fc=17.2MHz BW=1MHz
CAP 1 2 C=27PF
PLC 2 0 L=1uH C=56PF
CAP 2 3 C=4PF
PLC 3 0 L=.1uH C=80PF
CAP 3 4 C=3PF
PLC 4 0 L=1uH C=80PF
CAP 4 5 C=3PF
PLC 5 0 L=1uH C=80PF
CAP 5 6 C=4PF
PLC 6 0 L=1uH C=56PF
CAP 6 7 C=27PF
tia,
Remove "HeadFromButt", before replying by email.
M
maxfoo
Fc=17.2MHz BW=1MHz
CAP 1 2 C=27PF
CAP 2 3 C=4PF
PLC 3 0 L=.1uH C=80PF <<<<<<< L=1uH sorry!
CAP 3 4 C=3PF
CAP 4 5 C=3PF
CAP 5 6 C=4PF
CAP 6 7 C=27PF
how did that decimal point get there on plc 3 0??
inductors should all be 1 microhenry.
Q
qrk
Hi all,
Lots of books out there with normalized tables. Go to a technical
university library and spend a few hours pouring thru some filter
books. You can use Linear Technology's FilterCad to see what sort of
filter type and order you need. Then hit the tables and make an LC
filter. The best book I have found is "Simplified Modern Filter
Design" by Philip Geffe, circa 1963. You can sometimes find this book
in a university technical library. It has an excellent treatment of
basic filter design and how to go from a low-pass prototype to other
filter types.
For your particular filter, you might consider a loose-coupled design,
also called coupled resonators. Good for Q > 10. Your design will just
fit into this category if you don't mind some imperfection. This type
of design produces nice component values. "Electronic Filter Design
Handbook", by Arthur Williams and Fred Taylor (ISBN 0-07-070434-1),
page 5-19 has info.
Mark
R
Robert C Monsen
Paul Burridge said:
Hi all,
p.
Download the freeware filter design software from
http://www.nuhertz.com/
Their UI is, uh, colorful, but it seems to work. Pay attention to the source
and load impedance. Also, it doesn't like 'engineering' notation (eg:
17.2Meg), so use scientific notation like 17.2e6 instead.
The freeware only designs filters to 3rd order, so if you need better than
that, either dig it out of a book or buy the software. However, it does both
passive and active filters. Its a bargain at twice the price... ;)
Regards,
Bob Monsen
T
Tom Bruhns
Download RFSim99 and let it do it for you. Download Filter Design
from AADE's site and let it do it for you. Download NuHertz's demo
version of their filter design software and let it do it for you.
There may even be web aplets that will do it for you. And then you
can play with configurations and shape factors and the inevitable
tradeoffs between complexity and shape factor.
Cheers,
Tom
R
Reg Edwards
For a very simple bandpass design program download program BANDPAS1 from
website below. Also obtain response versus frequency. Download in a few
seconds and run immediately.
Regards from Reg, G4FGQ
For Free Radio Design Software go to
http://www.btinternet.com/~g4fgq.regp
A
Active8
wtf?
I don't mind
John
He already has a book with a fair amount of tables and all the
explainations on how to go about the design. I'm wondering WTF
here. Hey paul. wtf?
P
Paul Burridge
Fair point. I just wondered if anyone had a design similar to
requirements *already* lying around they might post it, that's all.
Save me a bit of scrawling and button-pushing. I didn't wish to put
anyone out.
Thanks to all who responded, BTW. Some very useful steers.
P
Pete KE9OA
Hi Paul,
E-mail me directly and let me know how many poles you need. I
have the AADE program, and I will be glad to do that for you.
Pete
John Jardine
Paul Burridge said:
Hi all,
p.
The simplest filter that'll get you by, is this one. (a couple of tuned
circuits with a bit of top-coupling :) ...
___ ||C1
-|_R_¦------.----.-------||-------.----.-------, O/p
Source |L2 |C2 || |C2 |L2 |
I/p | | | | .-.
C| --- --- C| | |load R
C| --- --- C| |R|
C| | | C| '-'
GND GND GND GND GND
F1=16.2e6 'lower limit MHz
F2=18.2e6 'upper limit MHz
R=50 'Ohms source and load impedance
Pi=3.142
C1 = (F1+F2) / (4 x Pi x F1 x F2 x R)
C2 = F1 /(Pi x F2 x (F2-F1) x R)/2
L2 = 2xR /(4 x Pi) x (1/F1 - 1/F2)
The inductors end up being quite small but a couple of loops of wire cost
nothing. At 25megs the output is down to about 3% , which is not bad.
This particular style is the "3 element" design and from the traditional
"Constant K" filter stable. The pleasantly simple to design "constant K's"
and associated "M derived" filters, can be easily and freely used for most
day-to-day electronics work.
Exact Filter design, or 'synthesis' as they nowadays prefer to call it, can
be a nightmare if you're coming in from scratch. Even using a filter design
programme requires a good knowledge of filter types/performance/spec's
before data can begin to be entered.
If not using a prog' you move onto the more vexing method of having to
design an initial (prototype) low-pass filter, either via precalculated
tables or computing the required co-efficients, then mathematically
transforming the low-pass values into a bandpass (etc) design. For higher
order filters it can be ball-acheing drudgery and even then inductor
resistance has a nasty habit of spoiling that pristine work of art. (not a
problem with DSP filters).
I can't suggest a decent book, as the general purpose books seem over
complicated and destined to be written by maths people for maths people.
(The old GPO line-comm's manuals have useful notes on the 'K and M '
filters).
regards
john
B
bg
Go to Alt Binaries Schematics -
bg
Paul Burridge wrote in message
Joel Kolstad
I'd suggest Temes and LaPatra, "Circuit Synthesis and Design." Now out of
print, but occasionally you can find a cheap old copy used.
I'd also suggest the original poster does a couple of the exercises (he
might have already), doing what you describe with building a low frequency
prototype filter and then transforming it to a different type and frequency
range, but just for, e.g., a second order filter. There's not much to be
gained by doing the 'drudgery,' as you say, for a higher order filter other
than proficiency in aithrmetic.
---Joel Kolstad
A
Active8
anyone out.
Yes. I had to check my disorganized drive to make sure I'd been to
all those links. BTDT. I like having tools like that around to
compare what they say with what I figgered out on paper.
Q
qrk
Hi all,
Since your too lazy to do this, here, have a few designs. You can run
these on LTSpice. What is reasonably good shape factor?
Mark
Butterworth, pi-input, 1st-order low-pass prototype
Vin 1 0 AC 2.0000V
Rin 1 2 50.000
L1 2 0 26.899n
C1 2 0 3.1831n
Rout 2 0 50.000
..AC DEC 396 253.58kHz 1.1667GHz
..PROBE
..END
Butterworth, pi-input, 2nd-order low-pass prototype
Vin 1 0 AC 2.0000V
Rin 1 2 50.000
L1 2 0 38.041n
C1 2 0 2.2508n
L2 2 3 5.6270u
C2 3 4 15.216p
Rout 4 0 50.000
..AC DEC 792 5.7378MegHz 51.560MegHz
..PROBE
..END
Butterworth, loose coupled, 2nd-order low-pass prototype
Vin 1 0 AC 2.0000V
Rin 1 2 50.000
C1 2 0 2.0654nF
L1 2 0 38.046nH
C2 2 3 185.01pF
C3 3 0 2.0654nF
L2 3 0 38.046nH
Rout 3 0 50.000
..PROBE
..END
Butterworth, pi-input, 3rd-order low-pass prototype
Vin 1 0 AC 2.0000V
Rin 1 2 50.000
L1 2 0 53.798n
C1 2 0 1.5915n
L2 2 3 7.9577u
C2 3 4 10.760p
L3 4 0 53.798n
C3 4 0 1.5915n
Rout 4 0 50.000
..AC DEC 1188 10.224MegHz 28.937MegHz
..PROBE
..END
Butterworth, loose coupled, 3rd-order low-pass prototype
Vin 1 0 AC 2.0000V
Rin 1 2 50.000
C1 2 0 1.4607nF
L1 2 0 53.798nH
C2 2 3 130.84pF
C3 3 0 1.3299nF
L2 3 0 53.798nH
C4 3 4 130.84pF
C5 4 0 1.4607nF
L3 4 0 53.798nH
Rout 4 0 50.000
..PROBE
..END
Butterworth, loose coupled, 8th-order low-pass prototype
Vin 1 0 AC 2.0000V
Rin 1 2 50.000
C1 2 0 511.07pF
L1 2 0 137.94nH
C2 2 3 109.63pF
C3 3 0 457.95pF
L2 3 0 137.94nH
C4 3 4 53.121pF
C5 4 0 527.60pF
L3 4 0 137.94nH
C6 4 5 39.985pF
C7 5 0 543.91pF
L4 5 0 137.94nH
C8 5 6 36.809pF
C9 6 0 543.91pF
L5 6 0 137.94nH
C10 6 7 39.985pF
C11 7 0 527.60pF
L6 7 0 137.94nH
C12 7 8 53.121pF
C13 8 0 457.95pF
L7 8 0 137.94nH
C14 8 9 109.63pF
C15 9 0 511.07pF
L8 9 0 137.94nH
Rout 9 0 50.000
..AC DEC 3170 15.208MegHz 19.453MegHz
..PROBE
..END
