want to know a value of transistor
Discussion in 'General Electronics Discussion' started by jay_3189, Sep 24, 2013.
  1. jay_3189
    jay_3189
    11
    Sep 19, 2013
    I want to control a 6 solenoid valves(Operates at 24DCV and 0.5A) with the use of 6 relays connected to an Arduino's 6 pins via 6 BJT(NPN) Transistor.
    The Arduino output pin is 5V and can source 40mA maximum.
    I would like to use a relay to switch the valve on and off.
    So, suggest me that which transistor is better to use here and value of resistor that I have to put between arduino and transistor.
    and DC voltage for relay to operate.
  2. Fish4Fun
    Fish4Fun So long, and Thanks for all the Fish!
    464
    105
    Aug 27, 2013
  3. (*steve*)
    25,497
    2,839
    Do you want to use the transistor to turn the valve on and off, or do you want to use a transistor to switch a relay to switch the valve?
    It's hard to point you to an appropriate transistor. To switch a relay, a BC548 or a 2N2222 might both be acceptable. What value base resistor? Possibly between 120 ohms and 1k depending on the load and the gain of the transistor. Also don't forget a diode across the load if it is inductive.
    The voltage for a relay is the rated voltage. If you've got a 5V supply, you would probably choose a 5V relay (a relay with a 5V coil, the contacts are rated for the maximum load they can switch)
