Want simple strobe circuit
Discussion in 'Misc Electronics' started by Mike C, Dec 7, 2003.
  1. Mike C
    Mike C Guest
    Good Folk,
    I'm looking for a simple strobe circuit for a fairly high powered strobe
    light to flash once or twice a second to be used as a beacon. I can find a
    number of circuits, but they all use mains input, and I want to run this one
    from a 12V car battery.
    Any pointers much appreciated.
    Mike.
    WARNING: My e-mail return address is bogus to confuse the automated spam
    address gatherers.
    Mental decryption required:
    mikabel#ntlworld*com
    where * = 'dot' and # = 'at'
  2. Michael
    Michael Guest
    In case you decide you can use less than a "fairly high powered" strobe,
    <www.allelectronics.com>
    They have complete, ready to run, 12vdc 150 ms strobes for $8.95
    120 flashes/minute
    Your choice of red, green, blue,amber, or clear lens
  3. Mike C
    Mike C Guest
    Thanks very much, I had a look, and the unit looks interesting - in fact,
    being waterproof (weatherproof) makes it something especially to consider. I
    think I'll get one and see, but I really did want something bright, so if
    anybody else has further information on a more powerful unit, it would be
    most appreciated.
    The same shop is selling a variable flash rate unit, but they say from evert
    two to three seconds, and there again, I wanted a faster rate. Do you know
    what power light it uses? The description doesn't say.
    Thanks again,
    Mike.
  4. Michael
    Michael Guest
    Sorry. All I know about those strobes is what I posted, taken from the
    catalog. Coincidentaly I was looking at the catalog early this week,
    remembered seeing the strobes when I read your post. Even a tiny strobe
    is eye-catching in the dark, even from a mile or more away. I had
    first-hand experience with USAF survival strobes many years ago, and the
    tubes in those are small. Maybe you don't actually need a huge tube?
    I'm thinking about getting one of the All ELectronics strobes (clear
    lens). If it's not blindingly bright I'll put it on the front of my
    bicycle.
  5. Mike C
    Mike C Guest
    Thanks again, Michael,
    As I said, I'll get one and have a look. If it isn't bright enough for what
    I want (visibility from around 10 miles), then I won't have lost enough to
    cry over. Worth a shot!
    Regards,
    Mike.
  6. Michael
    Michael Guest
    How 'bout giving us a review after you've torn into it?
  7. Mike C
    Mike C Guest
    Well, I tried to order the strobe, but it didn't work because I was ordering
    it from England, and the only countries they mail to are the USA, Mexico and
    Canada. What a bum rap!
    I'll repost the request for a circuit and see what interest I can raise.
    Thanks for your help, though,
    Mike.
  8. Here is one circuit example:
    http://www.epanorama.net/circuits/strobo_12v.html
    In the highest setting it could just do 2 flashes per second
    at highest power setting that was as brigt as one flash
    made by the flash unit of those disposable cameras.
    Actually the circuit uses parts from such camera
    (flash tube, main capacitor and trigger transformer).
    This circuit is triggered from some external triggering source
    (so you send pulses to trigger input at the rate you want this
    to flash).
    Other links that coul be useful are:
    Stroboscope controller (works with above circuit)
    http://www.epanorama.net/circuits/strobocontrol.html
    More stroboscope links and information
    http://www.epanorama.net/links/lights.html#strobe
  9. Mike C
    Mike C Guest
    Thanks very much, Michael.
    In fact, I think I have found what I was looking for. I'm busy building it.
    Mike.
  10. Gary Lecomte
    Gary Lecomte Guest
    There is a pretty good 12 volt strobe project on my site that may be
    useful for you.
    A lot of these cheap strobes, for sale on the web are just that.
    "CHEAP, made with surplus parts"!
    Anyway if your interested, have a look at:
    http://www3.telus.net/chemelec/Projects/Projects.htm
    Gary
