D
DD
I have a flat screen LCD TV that I want to mount on the wall. There are
no power points where I want to put it so my first thought was to put
the power point behind the TV. Because of the depth of the mains Plug
and Socket, it means that I will have to pack out the mounting. This is
the easiest solution, but it will make the mounting and the packing
visible when you walk into the room. I'm sure I am not the first one to
come up against this problem so I'm wondering if others have found a
solution.
It is possible to buy special recessed sockets in the US which allow
the plug and socket to be below the wall surface (they are called Clock
Boxes),but I cannot locate anything like it in Australia. Perhaps
someone will know of something similar. See:
http://powerbridgesolution.com/home.html
http://www.hometheaterblog.com/images/2006/05/clockbox.jpg
How were the cables hidden when you wall mounted your Plasma or LCD TV?
DD
solution.
DD
