Wahl "Peanut" Electric Razor blown
Discussion in 'General Electronics Discussion' started by SHesington, Aug 21, 2017.
  1. SHesington
    SHesington
    Aug 21, 2017
    I just returned from the UK last week, and while there I plugged my Wahl razor into an outlet using an adapter. However, apparently it wasn't a convertor as well, because my razor "popped" and was instantly dead.
    Is this repairable? If so, can I do it myself or do I need to have it done by an expert?
  2. Alec_t
    Alec_t
    2,759
    735
    Jul 7, 2015
    Welcome to EP!
    The most likely fault is a burnt-out coil. I doubt repair would be economical.
  3. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    I would suspect the manufacturers anticipated this possibility and fitted some circuit protection device - likely and in-line fuse or such. It should be readily apparent if it is a 'replaceable' item.
  4. 73's de Edd
    73's de Edd
    2,805
    1,176
    Aug 21, 2015
    Sir SHesington . . . . . . .
    I would fully expectorate that you hit the unit with a FULL . . . and that's being hea-veeeee on the FULL . . . 220/40 and it zapped the hash inductor that passes off AC to be converted to DC with the Full Wave Bridge and then goes directly into the units "Peanut " powered 5 Watt 120VDC motor.
    Pull out ye olde tyme ohm metre and see that the motor was probably saved, but the 47uh inductor is open circuit, while some of the 4 junctions of the FWB might have also crunched down.
    INTERNAL REFERENCING:
    [​IMG]
    73's de Edd
  5. davenn
    davenn Moderator
    13,502
    1,830
    no image to see
