W600-pico webserver
Discussion in 'Microcontrollers, Programming and IoT' started by Harald Kapp, Mar 23, 2020.
  1. Harald Kapp
    10,025
    2,138
    Just got me a pair of W600-pico modules with built-in micropython interpreter.
    These modules are relatively recent and documentation is scarce.
    Using REPL via terminal and accessing the filesystem via ftpserver works like a charm.
    Where I'm stuck is this: Could anyone point me to info how to create a webserver in mircopython for these modules so I can read input and control outputs via a HTML page?
  2. Harald Kapp
    10,025
    2,138
    I found out how to do it by cobbling together info from several websites and tutorials:
    Code:
    # based mainly on https://www.youtube.com/watch?v=GVMuER7A770
    from machine import Pin
    import network, gc
    import easyw600, w600
    # setup garbage collection
    gc.collect()
    print("Connecting to local WiFi") #debugging
    # connect to local WiFi network
    ssid = "My_Dark_Home_Network"
    password = "HartToTell"
    easyw600.connect(ssid, password)
    print("Connection successful")
    #print(sta.ifconfig())
    # setup the webserver
    try:
        import usocket as socket
    except:
        import socket
    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM) # create new socket, address family type = AF_INET, socket type = SOCK_STREAM
    s.bind(('', 80))
    s.listen(5) # accept connections. backlog = 5 = max. number of unaccepted connections before refusing new connections
    # interact with the hardware
    led = Pin(Pin.PA_00, Pin.OUT, Pin.PULL_FLOATING)
    led_off = 1 # inverted logic
    led_on = 0
    # web page data
    def web_page():
        file = open("index.html", "r")
        page = file.read()
        file.close()
        return page
    # this is the main loop to handle requests
    while True:
        conn, addr = s.accept() # accept connection with a new socket object "conn" to remote address "addr"
        request = conn.recv(1024) # receive from connected socket "conn" using 1024 byte buffer
        print(request) # for debugging only
        if "GET /?led=on" in request:
            led.value(led_on)
        if "GET /?led=off" in request:
            led.value(led_off)
    #    led_status = ("ON", "OFF") led.value() ==1 # this should be valid python code, too, but I prefer the better readable form below.
        if led.value == 1: # same as before but imho better readable
            led_status = "ON"
        else:
            led_status = "OFF"
        response = web_page() % led_status # insert the actual status into the web page
        print(response) # debug
        conn.send("HTTP/1.1 200 OK\n")
        conn.send("Content-type: text /html\n")
        conn.send("Connection: close\n\n")
        conn.sendall(response)
        conn.close()
    You need the index.html file, too:
    Code:
    <html>
    <body>
        <h1>Hello - This is my micropython webserver's index.html</h1>
        <p>LED Status: <strong>%s</strong></p>
        <p><button onclick="window.location.href = '/?led=on'">ON</button></p>
        <p><button onclick="window.location.href = '/?led=off'">OFF</button> </p>
    </body>
    </html>
Similar Threads
Loading...
