volume control for clock
Discussion in 'Electronic Basics' started by Socrates, May 21, 2008.
  1. Socrates
    Socrates Guest
    Hello,
    I have an electronic quartz clock with chimes that needs a volume control.
    It has a 2 1/4 speaker and is way too loud for the room it is in. Is there
    any place that makes a inline volume control that I might be able to use to
    adjust this so it wouldn't be so loud. Please reply to the group.
    Thanks, Marty
  2. Lord Garth
    Lord Garth Guest
    Place a variable resistor in parallel with the speaker and adjust until you
    get a
    reasonable volume. You can then replace the variable resistor with a fix
    resistor of similar value.
  3. If it's merely a clock, chanced are good that it's a piezoelectric
    transducer, ie quite high impedance. So he may need to start with
    quite a high value of resistor.
    Michael
  4. Lord Garth
    Lord Garth Guest
    He said 2.25" speaker so maybe not!
  5. He did, I missed that.
    It seems odd though, because in a straight alarm clock (as opposed to
    a clock radio) all the ones I've looked at use a piezoelectric transducer.
    Michael
  6. Lord Garth
    Lord Garth Guest
    I'd agree, it seem that only clock radios still use a speaker for the alarm.
    I do like John's approach to balance the load impedance however. This
    is an L pad.
  7. neon
    neon
    1,325
    Oct 21, 2006
    in parrallel you are kidding right?
  8. neon
    neon
    1,325
    Oct 21, 2006
    add a pot in series with the speaker not in parallel.
