P
P E Schoen
I have a toroid core that I previously wound based on my idea for using 600
Hz or 1kHz or so to get higher power. The core is about 1.6" deep and 3.4"
diameter with a 2" diameter hole. This is probably the 80 VA core from
http://www.toroid.com/standard_transformers/transformer_kits/transformer_kits.htm,
which is rated at 0.12V/turn. I wound it with about 100 turns of #18 AWG as
a secondary, and two windings of 8 turns each of #10 AWG as a primary. If
volts/turn is proportional to frequency, this should be 2 volts/turn at 1000
Hz, so I should be able to apply 16 VAC to the primary in a push-pull
configuration, using a 12 volt supply. And I should be able to get 150 VAC
out.
I measured the inductance of each primary coil as 180 uH, and the secondary
is 3.2 mH. I did a simulation with a FWB rectifier and 680 uF filter
capacitor, and I got 19 to 27 amps in each MOSFET during the ON cycle, and
1.57A at 157V into the 100 ohm load, for 246 watts. The input power is 250
watts, for 98.6% efficiency (probably unrealistic). So far, so good.
Now I disconnect the secondary, and my input is 120 watts. This is 40 watts
in each of the primary coils which I have designated as 10 uOhms resistance.
The MOSFETs (IRF2903ZS) dissipate only 165 mW. The 12V source is supplying
11 A RMS and it has a 2 mOhm resistance, so that's not where the extra 40
watts is coming from. The current through the source varies between +20
and -8 amps on one cycle and 6.2 to -24A on the other.
My question is if this is a normal magnetizing current for such a
transformer. When I change the parameters to what the transformer probably
would have at its original rating of 120 VAC, 60 Hz, with 0.12 V/turn, I get
3.2 H, and the magnetization current is about 166 mA RMS. The expected
current at its 80 VA design is 80/120 or 667 mA, about 4 times the no load
value.
And my modified transformer should be 1.33 kVA with a primary current of 111
amps, which is ten times the magnetizing current.
Magnetic theory is not my strong point. Are these figures about right? Is
this a reasonable design for a 1 kVA DC-DC converter? I like the fact that
the MOSFETs run so cool. Size and weight are not a huge factor. The iron
core toroid should be much more rugged than a ferrite design, and may be
similar in cost, especially for small quantities. And the electronics should
be very simple. A 500 watt DC-DC converter costs about $250, and two of them
would be 2.4 x 1 x 4.6 inches, and weigh about 0.5 kG or 1 .1 pound. But at
best it's 90% efficient so it would need to dissipate 100 watts of power.
Mine would be about 10 times larger and heavier, but cost about 1/5 that of
the Lambda converter: http://us.tdk-lambda.com/lp/ftp/Specs/paf500f.pdf.
If and when I finish a practical design and build and test this beast, there
are unknown factors that may come into play, such as losses at the higher
frequency. But AFAIK toroids like this can be used up to 2 kHz. According to
the following engineering bulletin
http://www.stacoenergy.com/pdf/updated/designengine.pdf, Staco variable
transformers can be used up to 2000 Hz with little or no derating. But of
course that does not imply a higher power output, so that may be misleading
or not directly applicable. However, I have seen data elsewhere that says
the usual (or somewhat thinner) nickel-steel laminations can be used at
least to 400 Hz and even over 1000 Hz.
Following is my LTSpice circuit:
Paul
===================== 12V-160V.asc =====================
Version 4
SHEET 1 880 680
WIRE 304 128 224 128
WIRE 320 128 304 128
WIRE 432 128 384 128
WIRE 496 128 432 128
WIRE 560 128 496 128
WIRE 592 128 560 128
WIRE 96 144 -160 144
WIRE 224 192 224 128
WIRE 320 208 272 208
WIRE 432 208 432 128
WIRE 432 208 384 208
WIRE 592 208 592 128
WIRE 496 224 496 128
WIRE -496 240 -576 240
WIRE 96 240 96 224
WIRE 96 240 -496 240
WIRE 96 256 96 240
WIRE 272 272 272 208
WIRE 272 272 224 272
WIRE 320 272 272 272
WIRE 416 272 384 272
WIRE -320 288 -384 288
WIRE -80 288 -256 288
WIRE -384 304 -384 288
WIRE -256 336 -256 288
WIRE 96 336 0 336
WIRE -496 368 -496 240
WIRE 304 368 304 128
WIRE 320 368 304 368
WIRE 416 368 416 272
WIRE 416 368 384 368
WIRE 496 368 496 288
WIRE 496 368 416 368
WIRE 592 368 592 288
WIRE 592 368 496 368
WIRE -160 384 -160 144
WIRE 0 384 0 336
WIRE -576 416 -576 240
WIRE 592 432 592 368
WIRE -320 464 -320 288
WIRE -208 464 -320 464
WIRE -80 464 -80 288
WIRE -48 464 -80 464
WIRE -576 528 -576 480
WIRE -496 528 -496 448
WIRE -496 528 -576 528
WIRE -384 528 -384 384
WIRE -384 528 -496 528
WIRE -256 528 -256 416
WIRE -256 528 -384 528
WIRE -160 528 -160 480
WIRE -160 528 -256 528
WIRE -80 528 -160 528
WIRE 0 528 0 480
WIRE 0 528 -80 528
WIRE -80 608 -80 528
FLAG -80 608 0
FLAG 592 432 0
FLAG 560 128 Vout
SYMBOL ind2 80 128 R0
SYMATTR InstName L1
SYMATTR Value 180µ
SYMATTR Type ind
SYMATTR SpiceLine Rser=10u
SYMBOL ind2 80 240 R0
SYMATTR InstName L2
SYMATTR Value 180µ
SYMATTR Type ind
SYMBOL ind2 240 176 M0
SYMATTR InstName L3
SYMATTR Value 32m
SYMATTR Type ind
SYMATTR SpiceLine Rser=200u
SYMBOL nmos -208 384 R0
WINDOW 3 56 102 Left 2
SYMATTR InstName M1
SYMATTR Value IRF2903ZS
SYMBOL nmos -48 384 R0
SYMATTR InstName M2
SYMBOL voltage -496 352 R0
WINDOW 123 0 0 Left 2
WINDOW 39 24 132 Left 2
SYMATTR SpiceLine Rser=2m
SYMATTR InstName V1
SYMATTR Value 12
SYMBOL diode 384 288 M270
WINDOW 0 32 32 VTop 2
WINDOW 3 0 32 VBottom 2
SYMATTR InstName D2
SYMATTR Value MUR460
SYMBOL diode 320 224 R270
SYMATTR InstName D3
SYMBOL polcap 480 224 R0
WINDOW 3 24 64 Left 2
SYMATTR Value 560µ
SYMATTR InstName C1
SYMATTR Description Capacitor
SYMATTR Type cap
SYMATTR SpiceLine V=600 Irms=2.9 Rser=0.018 Lser=0
SYMBOL res 576 192 R0
SYMATTR InstName R1
SYMATTR Value 100
SYMBOL voltage -384 288 R0
WINDOW 39 -43 57 Left 2
WINDOW 3 -192 268 Left 2
SYMATTR SpiceLine Rser=50m
SYMATTR Value PULSE(0 10 250u 10n 10n 495u 1000u 100)
SYMATTR InstName V2
SYMBOL voltage -256 320 R0
WINDOW 3 -322 268 Left 2
SYMATTR Value PULSE(0 10 750.5u 10n 10n 495u 1000u 100)
SYMATTR InstName V3
SYMBOL diode 320 144 R270
SYMATTR InstName D1
SYMBOL diode 384 384 M270
SYMATTR InstName D4
SYMBOL polcap -592 416 R0
SYMATTR Value 2200µ
SYMATTR InstName C2
SYMATTR Type cap
SYMATTR SpiceLine V=25 Irms=2.9 Rser=10m Lser=0
TEXT 72 384 Left 2 !K1 L1 L2 L3 1
TEXT -584 624 Left 2 !.tran 0 200m 0 1u startup
TEXT 160 440 Left 2 ;Primary 2x8 turns 2V/turn at 1000 Hz
TEXT 160 472 Left 2 ;25 A peak magnetizing current for 180u 1kHz
TEXT 160 496 Left 2 ;27 A peak current at 100 ohm load
out.
value.
Paul
Version 4
SHEET 1 880 680
WIRE 96 240 96 224
WIRE 96 256 96 240
WIRE 96 336 0 336
WIRE 0 384 0 336
WIRE 0 528 0 480
WIRE 0 528 -80 528
FLAG -80 608 0
FLAG 592 432 0
FLAG 560 128 Vout
SYMATTR InstName L1
SYMATTR Value 180µ
SYMATTR Type ind
SYMATTR InstName L2
SYMATTR Value 180µ
SYMATTR Type ind
SYMATTR InstName L3
SYMATTR Value 32m
SYMATTR Type ind
SYMATTR InstName M1
SYMATTR InstName M2
SYMATTR InstName V1
SYMATTR Value 12
SYMATTR InstName D2
SYMATTR InstName D3
SYMATTR Value 560µ
SYMATTR InstName C1
SYMATTR Type cap
SYMATTR InstName R1
SYMATTR Value 100
SYMATTR InstName V2
SYMATTR InstName V3
SYMATTR InstName D1
SYMATTR InstName D4
SYMATTR Value 2200µ
SYMATTR InstName C2
SYMATTR Type cap
