Volts and Amps
Discussion in 'General Electronics Discussion' started by John Steaver, Oct 28, 2015.
  1. John Steaver
    John Steaver
    35
    Oct 28, 2015
    Could you add amps onto volt or take away amps from volts?
  2. davenn
    davenn Moderator
    13,866
    1,958
    hi John,
    welcome
    no it doesn't work quite like that
    here's the Ohms Law Triangle showing how Volts, Amps (current) and Resistance interact with each other
  3. John Steaver
    John Steaver
    35
    Oct 28, 2015
    so what would happen if you tried? Would it still be the same voltage?
  4. davenn
    davenn Moderator
    13,866
    1,958
    As I said, you cannot, it doesn't work that way
    now lets look at a practical circuit
    So using the Ohms law triangle from my first post
    can you tell me the current flowing in this circuit ?
  5. John Steaver
    John Steaver
    35
    Oct 28, 2015
    1 amp?
  6. davenn
    davenn Moderator
    13,866
    1,958
    yes :)
    now change the battery voltage to 25V
    what is the current flowing now ?
  7. Colin Mitchell
    Colin Mitchell
    1,416
    313
    Aug 31, 2014
    You have to write a question using voltage and amps and we will correct it.
  8. davenn
    davenn Moderator
    13,866
    1,958
    note that in a series circuit, the current flow is the same everywhere
    so the current flowing through A1 at the top is the same as the current flowing through A2 at the bottom
  9. davenn
    davenn Moderator
    13,866
    1,958
    he's doing OK Colin, don't confuse him yet, lets work out way up
  10. John Steaver
    John Steaver
    35
    Oct 28, 2015
    2.5 amps? I think I get now, thanks for replying so quickly :)
    davenn and Martaine2005 like this.
  11. davenn
    davenn Moderator
    13,866
    1,958
    Yup :)
    so experiment with changing the resistor value, whilst keeping the voltage value constant
    see the effect that has on the current value
    cheers
    Arouse1973 and Martaine2005 like this.
  12. BobK
    7,682
    1,688
    Despite others attempts to answer, I have no clue what you are asking.
    Amps and volts measure two different things, it makes no sense to add one to the other or subtract one from the other. So the answer is yes, you could, but the result would be totally meaningless. For example what is 10V + 5A (the answer is 15, but 15 what?)
    Please explain what you are really thinking (which is what I think Colin was trying to ask.)
  13. davenn
    davenn Moderator
    13,866
    1,958
    he's now on the right path, Bob,
    He just didn't understand the relationship between volts and amps :)
  14. Martaine2005
    Martaine2005
    3,557
    967
    May 12, 2015
    I think you are doing a great job Dave of being a monitor! Make sure the threads don't go off track.
    He will learn faster without being confused by people like @CDRIVE .
    Keep up the good work. :)
  15. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    I am 1.8m tall and weigh 99kg. How can I add these? In fact, I need to do some subtraction:D.
    Martaine2005 likes this.
  16. davenn
    davenn Moderator
    13,866
    1,958
    hahaha yeah me too. if I was 99kg, I would be extremely happy (anywhere between 100 - 110kg would be awesome)
    D
  17. davenn
    davenn Moderator
    13,866
    1,958
    lol and this one is heading that way too, so lets stop whilst we are ahead :)
  18. CDRIVE
    4,960
    652
    May 8, 2012
    I'm here because the forum alerts said that Marty quoted me, mentioned my name or ... hell I don't know but I'm here, so let's try this. Way back when Dinosaurs ruled I was teaching basic industrial electronics. To help my students relate to the material world I told them to think of electrical circuits as plumbing, where Voltage is pressure, like (PSI) pounds per square inch. Current in Amps is equivalent to water "flowing" though the pipes and measured in gallons per minute (GPM). And finally Resistance (R) as being equivalent to how much water you can push through a 1/2" pipe in one minute as compared to a 2" pipe. The smaller the pipe the higher the resistance (Restriction) to water flow. The larger the pipe, the lower the resistance (restriction) to water flow. Think of a 1Ω resistor as a big pipe and a 10KΩ resistor as a small pipe.
    So if you grasp this you will see that "arbitrarily" doing math on any three of of the Ohms Law (a brilliant guy) elements is meaningless. Heck, that's why it called Ohm's "LAW". :) If you violate it you go to electronics San Quentin. :D
    Chris
  19. Martaine2005
    Martaine2005
    3,557
    967
    May 12, 2015
    SHhh..........:D
  20. BobK
    7,682
    1,688
    Yes, and they will tack on a charge of resisting arrest.
    CDRIVE likes this.
