Hi everyone. I'm new here. Wondering if anyone can help.
I'm trying to repair a Sony Micro Hi System...sony_hcd-bx77dbi
The CD player is not spinning. Think both the sled and spindle motors are not turning. I believe this is due to the voltage supply to the CD unit coming off the main board. If you have a look at the attached pic (part of the main board) there should be 3.3V going into the pins 1 and 17 of the output ribbon which goes to the CD player. But I'm getting weird voltages from -2.6V to +1V at both. There is a little cluster of transistors (the 3.3V regulator circuit) - Q302 Q303, Q392, Q361 and the voltages are mostly wrong (in the pic the numbers in Red are Sony's correct readings, the numbers in green are mine).
I thought it might be something to do with the zener diode (D304) so I swapped in a new one but still getting the same readings so could it be one or more of the 4 transistors - if so which one??? Q302's readings seem more or less correct but Q303's are just weird with the negative value on the collector. Any suggestions gratefully received...
Cheers
Tom
Cheers
Tom
