Voltage Stabilization?
Discussion in 'General Electronics Discussion' started by icor1031, Apr 27, 2010.
  1. icor1031
    icor1031
    65
    Apr 27, 2010
    At 3.1v and 150ohm I have .1441..?
  2. (*steve*)
    25,411
    2,779
    Aaah, no.
    Try using the values I gave you.
    25mA (0.025A) and the various resistors.
  3. icor1031
    icor1031
    65
    Apr 27, 2010
    31.875
    29.375
    16.875
    10.000
    25ma and 510o, 470o, 270o, 160o...?
    I probably don't understand what ^ means in math. :D
  4. (*steve*)
    25,411
    2,779
    I^2 means I squared (I x I)
    That should get you more reasonable answers :)
  5. icor1031
    icor1031
    65
    Apr 27, 2010
    That's what I thought I did..
    Is the first one 19921875?
  6. (*steve*)
    25,411
    2,779
    let me work through one with you.
    P = I^2 R
    = 0.025 * 0.025 * 150 (for 25mA through a 150 ohm resistor)
    = 0.000625 * 150
    = 0.09375
    So that resistor at 25mA is dissipating 0.09 Watts. Unless other constraints existed I would use a 1/4 W resistor.
  7. icor1031
    icor1031
    65
    Apr 27, 2010
    ~~Try connecting 1 in series with a 510 ohm resistor,
    So, my first answer was right.. just had the wrong decimal placement.
    I don't see how to do it with 2 or 3 LEDs, though. :S
  8. (*steve*)
    25,411
    2,779
    I didn't see a correct answer from you at all. Neither did I see the results of your calculation for the other resistor values.
    Did you ever read this?
    I know you didn't bother to answer me.
  9. icor1031
    icor1031
    65
    Apr 27, 2010
    ~~Did you wire them in series or parallel?
    *I wired 3 LEDs in series... pos power to pos led, neg led to pos led, neg led to pos led, neg led to neg wire.
    I did answer.
    ~~~Try connecting 1 in series with a 510 ohm resistor,
    **31.875
    ~I didn't see a correct answer from you at all. Neither did I see the results of your calculation for the other resistor values.
    I calculated that the same way you calculated this (which I came up with the same answer)
    ~P = I^2 R
    ~= 0.025 * 0.025 * 150 (for 25mA through a 150 ohm resistor)
    ~= 0.000625 * 150
    ~= 0.09375
  10. (*steve*)
    25,411
    2,779
    OK, so the answer is YES you wired them in series, but NO, not like the link showed (i.e. with a resistor)
    So the wattage for each of the 4 resistors would be?
Similar Threads
Loading...
