Voltage spike protection
Discussion in 'Electronic Design' started by Efthimios, Nov 19, 2008.
  1. Efthimios
    Efthimios Guest
    Imagine a device working at 1 Volt.
    I what to protect it from a voltage spike of 50 to 100 Volts.
    Does any know how to do this in a cheap way???
    Efthimios
  2. Rich Webb
    Rich Webb Guest
    You'll need to define your requirements for "protect." No over-voltage
    protection can react in zero time to clamp the voltage to (V-limit plus
    exactly 0 volts).
    Knowing how to do it cheaply requires more knowledge of what device and
    in what environment. Guessing the operating and maximum allowable
    parameters of an arbitrary device isn't productive.
  3. limit the current into the device to a safe value
  4. Efthimios
    Efthimios Guest
    -The spike has a duration of 0.2 to 0.3 seconds.
    -The device to be protected is a sensor with operation voltage of 1
    Volt and maximum allowed 1.5 Volts.
    -The sensor draws a less than 0.1 milliamp.
    -The device works under normal room temperature and humidity
    conditions
    -Cost preferably about a dollar.
  5. Rich Grise
    Rich Grise Guest
    Yes, but we frown on doing people's homework for them. Maybe check the
    other side of google for "transient protection" or so.
    Good Luck!
    Rich
  6. Eeyore
    Eeyore Guest
    TVS (transient voltage suppresor) if the energy is high otherwise a
    zener plus series R.
    Graham
  7. Eeyore
    Eeyore Guest
    But of what ENERGY ? That's critical. And source impedance ?
    Plus, that's a bugger of a voltage range to protect as it happens !
    Graham
  8. Eeyore
    Eeyore Guest
    Student you reckon ? Sounds too intelligent a question for that to me !
    Graham
  9. legg
    legg Guest
    Protection of power rails and signal lines pose differing problems.
    You'd have to be more specific about the actual node on the specific
    device that was threatened.
    RL
  10. Rich Grise
    Rich Grise Guest
    Well, it's homework season again on the NG. Haven't you noticed about a
    dozen new googlies, mostly obvious homework? (or, more likely, mid-terms.)
    I guess I should give him the benefit of the doubt. but at least I
    gave him a search term. :)
    Cheers!
    Rich
  11. Eeyore
    Eeyore Guest
    Yes, can't fault that one other than possible junction capacitance. The OP
    doesn't say how fast the signal is.
    Graham
  12. Jasen Betts
    Jasen Betts Guest
    ---+---[DEVICE]-+---[fuse]---
    4X silicon rectifier diodes
  13. whit3rd
    whit3rd Guest
    So, you need to put a network between the source and the sensor
    that passes 1V and 0.1 milliamp accurately (so less than 10 mV drop
    and less than 1 uA current error), but protects a sensor that
    undergoes
    some kind of failure at 1.5V, against inputs in the 100V range.
    Is that +100V? or could it be -100V?
    Usually, one would put a triggerable shunt across the sensor,
    and a small triac (or pair of SCRs) might do it. Most packaged
    surge protectors operate at much higher voltages, though,
    and sense-with-an-amplifier schemes have a few microseconds
    of delay.
  14. Jamie
    Jamie Guest
    If 1.5 volt is the max allowed, why not use the simple components
    that are out there already?
    2 sets of diodes to form 1.5 average break down joined back to back.
    this gives you a nice bi-directional clamp via some components that
    should be able to handle that through some kind of current limiting
    source, like a resistor.
    They also make TVS diodes...
    http://webpages.charter.net/jamie_5"
