Voltage sources in Parellel
Hello everybody,
What would happen if two voltage source are
connected in parallel.I think if the two voltages are of the same
voltage(say 'V') and amperage, the resultant voltage would be V itself.
But what happens if they are dissimilar(say 5 Volt and 3.3
Volt).Expecting your suggestions...
Regards,
Robotnik
A
Andrew Holme
Hello everybody,
Regards,
Robotnik
Real voltage sources have internal resistance. So there is always a (small)
resistor in series.
I think you are talking about ideal voltage sources, which do not exist. If
you connect dissimilar ideal sources in parallel, you get infinite current.
If you connect identical ideal sources in parallel, the voltage is indeed V
as you say; but if you connect a load, you cannot say how they share the
current drain. When you get infinity in the math, or too many unknowns, it
usually means the physical scenario is impossible in the real world.
L
Lefty
Hello everybody,
Regards,
Robotnik
Well an obvious example would be hooking two batteries of different
voltages in parallel, current would flow from the higher voltage to the
lower in the amount depending on internal resistenace of the battaries.
Jim Yanik
any Fluke differential voltmeter shows this.
They use a precision voltage source to buck against the measured
voltage,and use a null meter to zero out the current;then the Fluke readout
matches the unknown V source.
E
Emanuele
[email protected] ha scritto:
Hello everybody,
Regards,
Robotnik
If You work in AC, take a double outputs transformer as example
in DC instead as same battery
So in general: in parallel --> sum the current
in series --> sum the voltage
If they are not similar all depend by the internal resistor
(be careful, can damage the voltage source)
Emanuele
*** YOUR ELECTRONICS OPEN SOURCE ***
http://dev.emcelettronica.com
Progetti Completi:
[IperKEY-ResKEY] Chiave elettronica a microcontrollore
//TAGS:pic, Eeprom, Comparatori, Convertitori rampa, I2C
[IperCODE] Ricezione, visualizzazione e trasmissione codici RADIOCOMANDI
//TAGS:pic, Radiocomandi, routines, rolling code, UART, CCP1, LCD
