Voltage source with Low Quiescent and No Minimum Load
Discussion in 'Electronic Design' started by rich, Sep 10, 2012.
  1. rich
    rich Guest
    I need to provide a backup voltage to a device, the current requirement is 20uA. The device is battery powered. It is my understanding that zener regulator requires enough current to put the zener into regulation which would be too much for our battery life.
    I know there are voltage references out there for this but they all seem tobe in the $2 range, a bit pricey.
    Any elegant solutions?
    Rich
  2. mike
    mike Guest
    Since you have no requirements for nominal voltage,
    accuracy, stability, size, weight...and no notion
    of where the power comes from,
    I'd just use an old car battery. Even a dead one
    should do 20uA for a long time.
    The hardest part of a solution is defining the problem.
  3. TTman
    TTman Guest
    Rich
    CR2032 coin cell ?
    MCP1700 regulator ? has 1ua quiescent current...
  4. Guest
    Depends on voltage needed.
    Use a diode OR gate, where master supply voltage being slightly
    higher than the backup battery which is lithium.
