F
[email protected]
First, thanks to everyone who responded to my earlier question about
combining the secondaries on my toroidal transformer. That was the
thread from here: http://snipurl.com/1amow
I like the voltmeter test idea...I will try that method...thanks!
I'm preparing to build a power supply for a set of servo drivers for a
home workshop CNC router I designed. I can run these servos from
between about 17VDC up to 56VDC. According to the servo data sheet,
peak power is achieved at approx 41VDC, 3200RPM. However, due to some
of the other mechanical aspects of the machine, I'd may like to
perhaps run the servos at a lower voltage and speed.
The transformer has two 115V primaries, and two 33V secondaries, each
rated at 7A.
Q1:
Say I wanted to have the option of either "full' voltage (33V) or
"half" voltage (16.5V). Is there a way to wire the primaries of the
transformer (in series?) to produce half the rated output voltage,
across the secondaries? If this is possible, do I get 14A out of it?
It would be very cool if I could use this transformer and put a simple
switch on the front panel of my control box that says "full voltage or
half voltage". Then, I can experiment with the gearing in my power
transmission scheme, to get the best combination of power and speed.
Q2:
My household service is usually around 120VAC, so I think my 115V /
33V transformer is probably going to produce around 34 or 35 volts. I
realize that creating a truly regulated PS at some lower voltage is
way beyond the scope of what I'm trying to do here. So, instead of
regulating to lower than the 42VDC @ 14A expected final output of my
power supply, is there a simple way to induce an "extra" voltage drop
in the circuit? I know that the rectifier diodes in a full-wave
configuration are good for around a 2.4V drop -- what if I wanted to
create (for example) a 10V drop? Can it be (safely) done?
If this is possible, and my Q1 is possible, that would give me a lot
of options of "final" voltage out of my unregulated supply, at the
amperage I need.
Thanks again for your help...
-Chris
rated at 7A.
Q1:
Q2:
amperage I need.
-Chris
