Voltage Regulators
cmt23cmt23
Jun 12, 2012
Jun 12, 2012
I am in need of a voltage regulator, linear preferably, that I can use with a Variable input (Approx. 2-25v) and get 5v out. Something like a lm340 or lm341 just with a larger Vin range. Dont need surface mount just basic analog circuits design. Power usage is in the low to mid mA. Can anyone recommend something for me?
Harald Kapp
13,738
13,738
Impossible.
A linear regulator can only regulate to (Vin-Vdrop) where Vdrop is the voltage drop across the regulator and is at least on the order of 1 V for low drop regulators. Therefore you need at least 6 V, if not more, to generate 5 V. It is impossible with Vin = 2 V, as you request.
You will have to resort to a switch mode regulator. Look at TI, Maxim, Linear Technology etc. for a component matching your requirements.
Harald
7,682
7,682
Well, a linear regulator that takes in 2V and puts out 5V would be quite an accomplishment!
You need a DC-DC converter. You can find very cheap units on EBay.
