Voltage regulator stuck closed.
Discussion in 'Electronic Basics' started by [email protected], May 12, 2005.
  1. Guest
    My Technos water purifier/ionizer refuses to turn itself off. After
    inspecting I've found a stuck closed voltage regulator. I'm trying to
    locate a compatible regulator. Where can I find a voltage regulator
    replacement for this one?
    Thanks.
    FW0128 FQP W 50N06
    Details problem see http://snipurl.com/eu3m
  2. Jeroen
    Jeroen Guest
    This is not a voltage regulator but a N channel MOSFET. Datasheet at
    http://www.fairchildsemi.com/pf/FQ/FQP50N06.html
    FW0128 is probably some production date code. The 'W' seems to be the
    Motorola logo. So the full part number is FQP50N06.
    Hope this helps,
    Jeroen
  3. $1.36 at Mouser.
  4. Guest
    "Travis Jordan" wrote
    Thanks for searching. And thanks for the correction, Jeroen, which
    allowed me to replace it with a Motorolla N-Channel (MTW 14N50E 01,
    attached to a larger heat-sink) I'd salvaged from a computer monitor. I
    don't believe that salvaging a part from a computer monitor is
    professional but it seems to solve the problem quiet fine.
    Simon
  5. Rich Grise
    Rich Grise Guest
    You'd be surprised. :)
    Cheers!
    Rich
