Voltage Regulator help
Discussion in 'General Electronics Discussion' started by EleV^te79, Dec 4, 2014.
  1. EleV^te79
    EleV^te79
    35
    Dec 4, 2014
    Can anyone help me understand the numbers on this voltage regulator And what they stand for? I'm pretty sure the top #'s are the actual part # but what's the middle line? Is it possible to find the same exact one with the same #'s ?
    Thanks in advance for your help.
  2. Supercap2F
    Supercap2F
    550
    150
    Mar 22, 2014
    So are you trying to replace it? If so, the data sheet is here, and you can find the same part for sale here. It's an adjustable voltage regulator.
    Dan
    EleV^te79 likes this.
  3. EleV^te79
    EleV^te79
    35
    Dec 4, 2014
    Thanks Dan,
    Dan what do the numbers and letters represent on the middle line ? G40e8 V6?
  4. garublador
    garublador
    111
    43
    Oct 14, 2014
    Those other two lines are probably just stuff put on there that indicates things like when/where the part is made or what die revision is inside. You can search the ST website if you're really interested, but there's a very good chance you won't find anything. In other words, they mean something to ST, but are useless to the end user unless ST asks for them.
    Arouse1973, KrisBlueNZ and Supercap2F like this.
  5. EleV^te79
    EleV^te79
    35
    Dec 4, 2014
    Ok I wasn't sure if it was coded for amps or voltage or something like that. I know that the spec sheets give all that info. Thanks again !
    Supercap2F likes this.
