Voltage Regulating:Large input range
Discussion in 'General Electronics' started by SLK, Jul 3, 2003.
  1. SLK
    SLK Guest
    Hello,
    I am relatively new to power electronics, so I am hoping that I would
    get some help.
    I am trying to design a power circuit that has an input range of
    approximately 10 to 85 V DC. The desired output voltage is 12V at
    about 2-3 Amps.
    If anyone anyone could help me with any suggestions, I'd really
    appreciate that. The nearest I came to was Maxim MAX5003 IC which has
    the wide input range but locks below 25V. Is anyone aware of any part
    that would pass the whole range or is there any way I could switch
    between the MAX and another power circuit based on the input supply?
    Thanks in advance,
    SLK
  2. Robert Baer
    Robert Baer Guest
    Since the input voltage can go below the desired output, a composite
    buck-boost or Cuk circuit seems advisable.
    There are a lot of BICMOS switchmode regulator ICs that work; the
    UCC2801 has a turn-on threshold of 9.4V and is specified at 10V supply.
    The neat thing is that it has a built-in zener (about 14V if i
    remember), so a series current limiting supply resistor (30mA max) helps
    to achieve the wide range.
    Check out the UCCx800/1/2/3/4/5 series from TI.
    Besides, TI actually *makes* and *sells* the parts they advertise;
    Maxim has a nasty habit of not providing a number of their advertised
    parts, and distributors cannot even get samples.
