Voltage or PWM controlled resitor
Discussion in 'Electronic Design' started by Teten, May 21, 2007.
  1. Teten
    Teten Guest
    Hello
    How can I realize a voltage or PWM controlled resistor to change
    current into a LED based system ?
    Current = 10mA to 350mA
    DC voltage controlled resirtor or PWM (duty cycle) controlled resitor
    Thank you a lot for your help.
    Best regards,
    Teten
  2. Mook Johnson
    Mook Johnson Guest
    A current mode PWM controller will effectively drive the LED with a current
    instead of a voltage. Play some games with the voltage refereance and you
    should be able to get the range of currents you seek.
  3. Winfield
    Winfield Guest
    I'll see if I can answer your question. First, voltage-controlled
    current source circuits are often considered, and are a good way to
    make programmable currents. A simple current source can be created
    if the load is floating, rather than grounded.
    A true or "pure" current source, "sources" current into a grounded
    load, and this needs a power current mirror as part of its design.
    ASCII circuit diagrams for both of these have been posted here on
    s.e.d. multiple times, and are available with a Goggle search.
    Finally, let's address your question about a PWM resistor. While
    I wouldn't use a PWM resistor, per se, for your LED-current source,
    a PWM programming-signal makes plenty of sense. This can be used to
    create a PWM current (full on or off with a PWM ratio) into the
    mirror
    mentioned above, and if the mirror has a smoothing filter capacitor,
    then the PWM signal will create a steady programmable current out of
    the mirror into the LEDs.
