Voltage multiplier
Discussion in 'General Electronics Discussion' started by stari, Feb 9, 2016.
  1. stari
    stari
    18
    Oct 24, 2015
    Hello,
    i have a small project, where i must reach pulses cca 100V, frequency 10Hz, pulse width 5ms.
    My supply battery is 3.7V and i generate pulses with microcontroller.
    So, with a small transformer i can achieve 100V pulses, but the transformer is too big ! So i decide, to make a voltage multiplier, but,....have a little problems with this. Any suggestion?
    Thks from stari (Slovenia).
  2. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    What is the current needed at 100V/10Hz ?
  3. stari
    stari
    18
    Oct 24, 2015
    Thks for quick answer.
    I need this device as TENS - pulses should be 1-50 mA on 1KOhm load. Some machines have higher current, but i think 50 mA is enough.
    Also i can control output pulse Voltage, from 1 - 3,7V.
    Stari
  4. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    You can generate the high voltage at high frequency (100kHz) so using a smaller transformer. This would need to charge a capacitor which would be switched to the output.
    A rough calculation, possibly wrong, would require a 10μF 100V capacitor to hold 50mJ.
    The size of the pulse transformer you are using will depend on how well it is designed for the job.
  5. Alec_t
    Alec_t
    3,054
    833
    Jul 7, 2015
    100V and 50mA can be LETHAL, especially for anyone with a weak heart or pace-maker!! You should take great care when using this.
  6. AnalogKid
    AnalogKid
    2,568
    739
    Jun 10, 2015
    Most TENS units have a small switching power supply. This can be a non-isolated boost circuit of a fully isolated flyback, but either way there will be magnetics involved and that means some bulk.
    Boosting 3.7 V to 100 V is a ratio of 27:1. At 90% efficiency (a very high value), that becomes 30:1, so for a 50 mA output you need 1.5 A of input current. Your duty cycle is only 1:20 and that helps reduce the input current, but this still will be a hungry power converter. Another option is to let the flyback pulse be the output by shaping it with a clipper. Much more efficient, but not a cookbook design.
    TENS units are very inexpensive and tested and safe, so why do you want to build one?
    ak
  7. stari
    stari
    18
    Oct 24, 2015
    AnalogKid, i know, but i have such project to realize for my boss. (??). Ok, no problem, i will try by your suggestion.
    In fact, i will make TENS controlled by Android or iOS.
