Imagine I have 2 solar cells in my hand. They have an open circuit voltage of around 0.55V and a short circuit current of 4A
With some number of these (probably more than 2 of them) I can easily make a supply capable of 0.5V at 8A.
However, if this were the source, I'd probably put them in series.
MS, there's no insurmountable problem in creating a boost converter that can take 0.5V and pump it up to 12V. Doing it at high efficiency is another problem.
There are any number of mosfets with on resistances in the miliohm range that would drop only a tiny fraction of the voltage at the current contemplated.
Now it is true that it is difficult to consider a "joule thief" since these are essentially relaxation devices powered from the low voltage input, but it doesn't need to be so!
All you need is a low power source to bootstrap the device into operation (after which it may well be powered from it's output voltage).
There are significant technical challenges, your mosfet must have very low resistance, as must your inductor to allow the current to rise to 8A without losing a large fraction of the power to resistive losses.
Let's say that your combined mosfet, wiring, and inductor resistance would need to be below 6 milliohms -- that is the real challenge.
