Voltage Fluctuation
Discussion in 'General Electronics Discussion' started by alexanderfoti, Apr 19, 2015.
  1. alexanderfoti
    alexanderfoti
    24
    Jan 10, 2013
    Hi all
    On my diesel bike, I have a 12v fuel pump (piston type). As its a piston type pump, it causes voltage fluctuations.
    I also have LED brake lights, and it causes big problems with the brake lights flickering. It failed its last MOT on this. I disconnected the fuel pump, it passed, then I re-connected it again.
    This is what it looks like:
    I'm trying to fix it now, and I'm thinking, I can use a constant current driver to sort it out, like this:
    http://www.ebay.co.uk/itm/5A-Constan...item2ed0148934
    Any ideas on what I can use otherwise, something nice and easy like a massive capacitor [​IMG]
  2. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    You probably have a massive capacitor, called a battery. The problem could be voltage drop along the cables. Try connecting the pump directly to the battery.
    Arouse1973 likes this.
  3. alexanderfoti
    alexanderfoti
    24
    Jan 10, 2013
    Bingo, hole in one.
    Relay on its way to connect pump directly to the battery. Thanks!
Similar Threads
Loading...
